  3. Incomplete Frame Detection Question - Causes RR Loop On Kamstrup
Incomplete frame detection question - causes RR loop on Kamstrup
By L0uisc_iot , 27 January, 2026
Hi Kurumi,
I’m using Gurux DLMS with HDLC and based part of my receive logic on the examples in the Gurux repository. In particular, I copied the pattern here (https://github.com/Gurux/Gurux.DLMS.Net/blob/751914f4a9a6fd504e5b8c6430…) where a reply is treated as “no data yet” when:
reply.Error == 0 && reply.Data.Size == 0
This generally works, but I ran into a subtle issue during disconnect handling, specifically with Kamstrup meters.
What I’m seeing:
When I send an HDLC Disconnect (DISC), the meter correctly replies with UA.
UA is a valid HDLC control frame and has no DLMS payload, so reply.Data.Size == 0.
Because reply.Error == 0 && reply.Data.Size == 0 matches, my code enters the loop that sends Receiver Ready (RR) / continuation frames.
This causes Gurux to think more data is expected, even though the link was cleanly disconnected.
The request and response is:
TX: 7E A0 07 21 25 53 E0 16 7E // DISC
RX: 7E A0 07 25 21 73 E3 33 7E // UA
GXDLMSDirector decodes this correctly as DISC / UA.
My question:
Is the (reply.Error == 0 && reply.Data.Size == 0) condition intended to be used only for I-frames / DLMS-level continuation, and not for HDLC control frames like UA?
Should user code explicitly check the HDLC frame type (UA/DISC/SNRM/etc.) and avoid sending RR / GetMoreData in those cases?
Or is this a limitation/bug in the example that should be guarded with additional checks?
My workaround is to add a bool parameter which I set to true when sending disconnect. I add it to the clause checking for empty data above so I don't enter the while loop if it is true and I received a valid frame with no data. This fixes the issue. I just want to confirm the intended pattern so I can use it if there is something more explicit.
Thanks — and thanks for the excellent library.
L0uisc_iot
6 months 3 weeks ago
Any comments/updates on this?
5 months ago
Hi, I'm sorry for this. This…
I'm sorry for this. This was a specific version for one of the customers and was not planned to be added to GitHub.
Get the latest version. That will fix this.
L0uisc_iot
5 months ago
Hi, this is in the latest…
Hi, this is in the latest version of the example in the Gurux.DLMS C# library still. No recent changes happened in that part of the code. Am I misunderstanding you? Which latest version do you refer to?
5 months ago
Hi, I was too fast. This is…
I was too fast. This is now available on GitHub.
  • addCaptureObject as Class ID=01 (Data) (not 03 (Register))
  • L+G E355 Load Control
