  2. Long Reading Ends With "Invalid Frame ..." Error.
Long reading ends with "Invalid frame ..." error.
By abk964 , 16 May, 2025
Gurux DLMS for ANSI C
Long seances (hundreds of HDLC packets) ended with "Invalid frame..." errors. Same readings in Director are OK. Different devices.
What can I check by myself?
1 year ago
Hi, If the devices are…
If the devices are different, check that they have the same meter firmware.
You didn't tell what you tried to read, but I believe it's a profile generic.
You can usually ignore the Invalid frame error if you read only a few days from the profile generic at a time. So decrease the number of days that you try to read in one sitting.
abk964
1 year ago
Hi. Found my own mistake…
Hi.
Found my own mistake. Thanks.
