  3. Get Only Voltage and Current Python
get only voltage and current Python
By Reese , 26 July, 2023
Gurux.Serial
Is it possible to get just some parameters, e.g Voltage and current from a smart meter without using getAssociationView, I notice that this function gets some values, puts them in a text file and then reads the values required by user.
Is it always necessary to write the values into a text file and then read them.
Is there a function to read some values but not from that text file but get those values directly from the function.
I'm sorry for my english, my native language is spanish.
3 years 2 months ago
Hi, If you know what objects…
If you know what objects your meter have you can add those object to the code and read them without association view.
Something like this:
GXDLMSData d = new GXDLMSData("YOUR_OBIS_CODE");
Read(d, 2);
I believe this will help you.
