  3. Reading Meter NIK
Reading meter NIK
By BigAlex , 13 February, 2023
The NIK meter is not in the list of manufacturers, is it possible to add it yourself manually?
https://nik.net.ua/en/category/metering-devices
I attach the logs of the native program and Gurux:
230213 11:07:48:256 Information: "Port is opened"
230213 11:07:48:263 Mode E
230213 11:07:48:272 --> 2F|3F|21|0D|0A|
230213 11:07:49:623 <-- 2F|4E|49|4B|35|5C|32|4E|49|4B|32|33|30|37|20|76|32|2E|30|30|2E|0D|0A|
/NIK5\2NIK2307 v2.00.
230213 11:07:49:636 --> 06|32|35|32|0D|0A|
230213 11:07:50:191 <-- 06|32|35|32|0D|
230213 11:07:50:193 End Mode E
230213 11:07:50:196 COMMAND_SNRM:
230213 11:07:50:200 --> 7E|A0|0A|00|00|00|01|21|93|13|D1|7E|
230213 11:07:50:254 Receive 7E|A0|21|21|08|C6|08|51|73|EE|E4|81|80|12|05|01|80|06|01|80|07|04|00|00|00|01|08|04|00|00|00|01|53|3B|7E|
230213 11:07:50:270 261
230213 11:07:50:275 COMMAND_AARQ:
230213 11:07:50:276 --> 7E|A0|50|00|00|00|01|21|10|18|FC|E6|E6|00|60|3F|A1|09|06|07|60|85|74|05|08|01|01|8A|02|07|80|8B|07|60|85|74|05|08|02|01|AC|12|80|11|00|31|31|31|31|31|31|31|31|31|31|31|31|31|31|31|31|BE|10|04|0E|01|00|00|00|06|5F|1F|04|00|00|08|CB|00|80|9C|46|7E|
230213 11:07:50:472 Receive 7E|A0|3B|21|08|C6|08|51|30|EF|C8|E6|E7|00|61|29|A1|09|06|07|60|85|74|05|08|01|01|A2|03|02|01|00|A3|05|A1|03|02|01|00|BE|10|04|0E|08|00|06|5F|1F|04|00|08|80|00|04|B0|00|07|C4|42|19|7E|
230213 11:07:50:488 61
230213 11:07:50:491 00
230213 11:07:50:494 Get meter info
230213 11:07:50:498 --> 7E|A0|1C|00|00|00|01|21|10|84|8A|E6|E6|00|C0|01|81|00|01|00|00|60|01|0A|00|02|00|D1|77|7E|
230213 11:07:50:591 Receive 7E|A0|25|21|08|C6|08|51|30|07|FB|E6|E7|00|C4|01|81|00|0A|10|45|4D|37|31|35|41|5F|76|32|2E|30|30|2E|37|34|39|CC|7F|7E|
230213 11:07:50:604 --> 7E|A0|1C|00|00|00|01|21|10|84|8A|E6|E6|00|C0|01|81|00|01|00|00|60|01|0C|00|02|00|4B|3C|7E|
230213 11:07:50:687 Receive 7E|A0|18|21|08|C6|08|51|30|02|03|E6|E7|00|C4|01|81|00|06|10|02|00|00|62|A9|7E|
230213 11:07:50:703 --> 7E|A0|1C|00|00|00|01|21|10|84|8A|E6|E6|00|C0|01|81|00|01|00|00|60|01|01|00|02|00|C4|B7|7E|
230213 11:07:50:788 Receive 7E|A0|35|21|08|C6|08|51|30|CE|4E|E6|E7|00|C4|01|81|00|0A|20|4E|49|4B|20|32|33|30|37|20|41|52|54|20|54|2E|31|32|30|30|2E|4D|2E|32|31|00|00|00|00|00|00|00|00|4A|30|7E|
230213 11:07:50:821 --> 7E|A0|1C|00|00|00|01|21|10|84|8A|E6|E6|00|C0|01|81|00|01|00|00|60|01|00|00|02|00|7F|AB|7E|
230213 11:07:50:904 Receive 7E|A0|1D|21|08|C6|08|51|30|A1|F3|E6|E7|00|C4|01|81|00|09|08|23|07|10|01|11|76|20|18|D2|81|7E|
230213 11:08:36:522 --> 7E|A0|0A|00|00|00|01|21|53|1F|17|7E|
230213 11:08:36:566 Receive 7E|A0|0A|21|08|C6|08|51|1F|85|58|7E|
230213 11:08:36:701 Information: "Port is closed"
GXDLMSDirector 9.0.2302.0901
Log created 11:10:43
11:10:57 Initializing serial connection.
11:10:58 IEC Sending:/?!<CR><LF>
11:11:00 HDLC received: /NIK5\2NIK2307 v2.00.<CR><LF>
System.Exception: Manufacturer type does not match. Manufacturer is NIK and it should be grx.
в GXDLMSDirector.GXDLMSCommunicator.InitSerial()
в GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
3 years 7 months ago
Hi, Yes, you can add it by…
Yes, you can add it by yourself. Read the instructions here:
https://www.gurux.fi/GXDLMSDirector.Manufacturers
If you send the device template to me, it can be added so it's available for all users.
BigAlex
Thanks for the tip, if I…
Thanks for the tip, if I succeed, I'll be sure to share the result
BigAlex
Can you please tell me where…
Can you please tell me where can I change the SNRM request length to 12 bytes?
Gurux send only 9 bytes.
In the native program, the request looks like this
7EA00A00000001219313D17E
BigAlex
Can you add your own…
Can you add your own standard?
The native program seems to add a few bytes to the requests.
  • Olga
  • govendd
  • ratan1209
  • avadhesh.p
  • Peter Mudenda
