  3. DLMS Translator Python
By jrudilla , 14 December, 2021
Hi, I have a python code that translates the dlms frames, the problem is that I have realized that something does not work correctly.
This frame 01020203090C07E50C0D0110000000FFC400050000000005000000000203000500000000050000000
should give me:
<Structure Qty="03" >
<!-- 12/13/2021 4:00:00 PM+01:00 -->
<OctetString Value="07E50C0D0110000000FFC400" />
<Int32 Value="00000000" />
</Structure>
<None />
</Structure>
But failing I get this. I am missing the last item. <Int32 Value="00000000" />
</Structure>
<None />
</Structure>
</Array>
The code I am using is this.
bb = GXByteBuffer()
bb.setHexString(data)
t = GXDLMSTranslator()
data_xml = t.dataToXml(bb)
Thank you very much for your support.
4 years 10 months ago
There is one byte missing from your data. Append one zero like this:
01020203090C07E50C0D0110000000FFC4000500000000050000000002030005000000000500000000
jrudilla
Thank you very much, I had
Thank you very much, I had not realized it but my service was always leaving the last digit, it is already solved
  • APFC TEAM1
