  3. Landis+Gry E550 With 4G Modem
Landis+Gry E550 with 4G Modem
By XYTeoh , 14 October, 2021
Connecting Landis+Gry E550 to Gurux through 4G LTE network.
'Failed to receive reply from the device in given time' error occur
4 years 8 months ago
If I remember correctly Landis+Gyt E550 isn't using WRAPPER. Try to change it for the HDLC.
XYTeoh
Hi Kurumi,
Hi Kurumi,
I had test with HDLC, same error as "Failed to receive reply from the device in given time."
Check that you can access the meter and your port and address are correct. Change also your wait time higher. It might be that 5 seconds is not enough.
