  3. Meter ON or OFF Checking
Meter ON or OFF checking
By poojash , 1 October, 2021
Hi sir,
I want to check is the meter is ON or OFF. So please let me know how I can check using gurux library.
4 years 11 months ago
If the meter is off it doesn't usually answer, some meters have the battery.
If you want to check if the power supply is disconnected, you can use Disconnect control for that.
