PLATFORM VERSION INFO
Windows : 10.0.19043.0 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.8.4270.0 built by: NET48REL1LAST_C
clr.dll : 4.8.4390.0 built by: NET48REL1LAST_C
dfdll.dll : 4.8.4270.0 built by: NET48REL1LAST_C
dfshim.dll : 10.0.19041.1 (WinBuild.160101.0800)
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Users\rajan.kumar\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Gurux Ltd\GXDLMSDirector.appref-ms| resulted in exception. Following failure messages were detected:
+ Downloading http://www.gurux.fi/Downloads/gxdlmsdirector46/Application Files/GXDLMSDirector_8_2_2109_0301/Gurux.DLMS.AMI.Messages.dll.deploy did not succeed.
+ The remote server returned an error: (403) Forbidden.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [27-09-2021 15:08:47] : Activation of C:\Users\rajan.kumar\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Gurux Ltd\GXDLMSDirector.appref-ms| has started.
* [27-09-2021 15:08:47] : Performing necessary update check as specified by the deployment.
* [27-09-2021 15:08:48] : Consuming new update.
* [27-09-2021 15:08:50] : Installation of the application has started.
* [27-09-2021 15:08:52] : Processing of application manifest has successfully completed.
* [27-09-2021 15:08:52] : Found compatible runtime version 4.0.30319.
* [27-09-2021 15:08:52] : Request of trust and detection of platform is complete.
ERROR DETAILS
Following errors were detected during this operation.
* [27-09-2021 15:09:01] System.Deployment.Application.DeploymentDownloadException (Unknown subtype)
- Downloading http://www.gurux.fi/Downloads/gxdlmsdirector46/Application Files/GXDLMSDirector_8_2_2109_0301/Gurux.DLMS.AMI.Messages.dll.deploy did not succeed.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.SystemNetDownloader.DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader.DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState, X509Certificate2 clientCertificate)
at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.ConsumeUpdatedDeployment(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentUpdate(SubscriptionState& subState, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ProcessOrFollowShortcut(String shortcutFile, String& errorPageUrl, TempFile& deployFile)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.Net.WebException
- The remote server returned an error: (403) Forbidden.
- Source: System
- Stack trace:
at System.Net.HttpWebRequest.GetResponse()
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
I'm not sure if the reason for this has been found. We can't repeat this on any PC, but one of the references is invalid. The new version is released on Monday. I hope that it will solve your problem. Let me know if you still have problems with the new version.
after clicking OK, i am
after clicking OK, i am getting following error(attached)
Can you click the details and add them here. I believe that your PC is not supporting some localized settings.
I have sent the error to the
I have sent the error to the deployment server.
PS.
Details...
SOURCES
Deployment url : file:///C:/Users/rajan.kumar/AppData/Roaming/Microsoft/Windows/Start%20Menu/Programs/Gurux%20Ltd/GXDLMSDirector.appref-ms%7C
Server : nginx
Deployment Provider url : http://www.gurux.fi/Downloads/gxdlmsdirector46/GXDLMSDirector.applicati…
Application url : http://www.gurux.fi/Downloads/gxdlmsdirector46/Application%20Files/GXDL…
Server : nginx
IDENTITIES
Application Identity : GXDLMSDirector.exe, Version=8.2.2109.301, Culture=neutral, PublicKeyToken=fac3cc4fecb816b3, processorArchitecture=msil, type=win32
ERROR SUMMARY
WARNINGS
ERROR DETAILS
- Stack trace:
- Source: System
- Stack trace:
This is a strange error. It seems like you can't access the server. Have you installed the application from here?
https://gurux.fi/Downloads/gxdlmsdirector46/GXDLMSDirector.application
Yes, I downloaded the
Yes, I downloaded the application from https://gurux.fi/Downloads/gxdlmsdirector46/GXDLMSDirector.application
Can you try to download GXDLMSDirector again? If it fails, run this on your command prompt and add result here.
dotnet --version
C:\WINDOWS\system32>reg query
C:\WINDOWS\system32>reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\CDF
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v2.0.50727
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.5
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4.0
C:\WINDOWS\system32>reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\full" /v version
version REG_SZ 4.8.04084
The problem is still
The problem is still persisting on all the PC in my organization.
There is a new version released. Is this problem still happening?
I've tried installing it on a different network. It's working fine.
I think, there are some internal issue within the organization network.
Thanks for your support.
Hi Rajan,
Hi Rajan,
Thank you for this information. Reasons like this are always problematic because it's hard to know the reason.
In my organisation, i can connect internet through proxy only
Is it possible to install GXDLMSDirector through proxy
Thanks in advance
