Meter Conformance is invalid. Can you find <GXDLMSAssociationLogicalName> from the simulator_template.xml and check what is the value of <Conformance> tag?
The meter is returning IncompatibleConformance error. I believe that DeltaValueEncoding is causing it. DeltaValueEncoding is a new conformance bit and it might be that your meter can't handle it.
Try to add this line before you call aarqRequest in initializeConnection function.
hi kurumi tanx for reply the
hi kurumi tanx for reply the simulator_template is not generated after the console mentioned above and stops at the point as i mentioned above.
dlms.getProposedConformance().remove(Conformance.DELTA_VALUE_ENCODING);
