  3. Can't Change/write MonitoredValue In Limiter
Can't change/write MonitoredValue in Limiter
By alexcd , 24 April, 2024
Hello, I'm using a Python library and can't change the monitored value in the Limiter object. When I use Director everything works as expected, maybe I'm doing something wrong?
limiter = GXDLMSLimiter('0.0.17.0.0.255')
reg_obj = GXDLMSRegister('1.0.31.7.0.255')
limiter.monitoredValue= reg_obj
limiter.monitoredAttributeIndex = 2
self.reader.write(limiter,2)
Thanks for the answer.
2 years 6 months ago
Hi, Are you getting an error…
Are you getting an error from the meter? Have you changed the authentication level?
alexcd
I read on the forum that the…
I read on the forum that the object should be taken from the association and updated my code. But the result remained unchanged, I add the code and log.
limiter = self.reader.client.objects.findByLN(0, "0.0.17.0.0.255")
value = self.reader.client.objects.findByLN(3, "1.0.31.7.0.255")
limiter.monitoredValue = value
print("==========read===========")
read_mon = self.reader.read(limiter, 2)
print(read_mon)
print("==========write===========")
self.reader.write(limiter, 2)
print(read_mon)
From the log
TX: 16:39:08 7E A0 1A 02 21 05 FE 7D 8F E6 E6 00 C0 01 C1 00 47 00 00 11 00 00 FF 02 00 9B 28 7E
RX: 16:39:08 7E A0 20 05 02 21 1E 27 0F E6 E7 00 C4 01 C1 00 02 03 12 00 03 09 06 01 00 03 07 00 FF 0F 02 B0 07 7E
1.0.3.7.0.255 Ch. 0 Sum Li Reactive power+ (QI+QII) Inst. value
TX: 16:39:08 7E A0 29 02 21 05 10 10 48 E6 E6 00 C1 01 C1 00 47 00 00 11 00 00 FF 02 00 02 03 10 00 03 09 06 01 00 03 07 00 FF 0F 02 FD 21 7E
RX: 16:39:08 7E A0 11 05 02 21 30 CE 18 E6 E7 00 C5 01 C1 0C 3C 43 7E
TX: 16:39:08 7E A0 1A 02 21 05 32 1D 83 E6 E6 00 C0 01 C1 00 47 00 00 11 00 00 FF 02 00 9B 28 7E
RX: 16:39:08 7E A0 20 05 02 21 52 4F 87 E6 E7 00 C4 01 C1 00 02 03 12 00 03 09 06 01 00 03 07 00 FF 0F 02 B0 07 7E
Most likely the data is not being transferred correctly
Hi, Class id is changed from…
Class id is changed from Int16 to UInt16.
This is fixed for version 1.0.151.
https://gurux.fi/release/guruxdlmspython-10151
  • Victorian | WA 083148835648
