When trying to update a device using the DLMS.Director against the AMI, it seems that the director does not post the template id to the controller when updating a device. The TemplateId of the "UpdateDevice" is 0, but the Device.Id is not (!= newDevice).
This throws an exception because of the fk constraint on template.
SQLClient Exception:
: 'The UPDATE statement conflicted with the FOREIGN KEY constraint "FK__GXDevice__Templa__628FA481". The conflict occurred in database "Dev", table "dbo.GXDeviceTemplate", column 'Id'.
You are right and I know the reason for this. There was a modification for one of our clients and it broke the GXDLMSDirector compatibility. This is fixed and the new version is released tomorrow after the testing.
