  3. PushSetup - Error Reading Attribute 2
PushSetup - error reading attribute 2
By MNN , 15 February, 2021
Gurux.DLMS.AMI
Hello.
An error occurs while reading an object:
Gurux.DLMS.AMI.Reader.ReaderService[0]
Failed to Read 0.100.25.9.0.255:5. Access Error : Device reports a unavailable object.
5 years 5 months ago
Meter is sending a push message and at least one of the push message objects is not in the database. Can you add a hex trace from the push message so I can check what are the push objects?
MNN
Hello.
Hello.
Reading: 0.100.25.9.0.255
TX: 09:16:38 7E A0 19 03 0F 32 4C 61 E6 E6 00 C0 01 C1 00 28 00 64 19 09 00 FF 02 00 26 14 7E
RX: 09:16:38 7E A0 6C 0F 03 52 5B 3A E6 E7 00 C4 01 C1 00 01 05 02 04 12 00 01 09 06 00 00 60 01 00 FF 0F FF 12 00 00 02 04 12 00 28 09 06 00 64 19 09 00 FF 0F 01 12 00 00 02 04 12 00 28 09 06 00 64 19 09 00 FF 0F 02 12 00 00 02 04 12 00 6F 09 06 00 00 13 00 00 FF 0F 05 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 E7 2E 7E
TX: 09:16:38 7E A0 19 03 0F 54 7C 67 E6 E6 00 C0 01 C1 00 28 00 64 19 09 00 FF 03 00 FE 0D 7E
RX: 09:16:39 7E A0 1E 0F 03 74 5C 1D E6 E7 00 C4 01 C1 00 02 03 16 01 09 06 00 00 00 00 00 00 16 00 A5 BE 7E
TX: 09:16:39 7E A0 19 03 0F 76 6C 65 E6 E6 00 C0 01 C1 00 28 00 64 19 09 00 FF 04 00 F6 40 7E
RX: 09:16:39 7E A0 12 0F 03 96 74 4E E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
TX: 09:16:39 7E A0 19 03 0F 98 1C 6B E6 E6 00 C0 01 C1 00 28 00 64 19 09 00 FF 05 00 2E 59 7E
RX: 09:16:39 7E A0 11 0F 03 B8 C5 A3 E6 E7 00 C4 01 C1 01 0B 3B 0E 7E
fail: Gurux.DLMS.AMI.Reader.ReaderService[0]
TX: 09:16:39 7E A0 19 03 0F BA 0C 69 E6 E6 00 C0 01 C1 00 28 00 64 19 09 00 FF 06 00 46 73 7E
RX: 09:16:39 7E A0 12 0F 03 DA 1C C6 E6 E7 00 C4 01 C1 00 11 01 92 5C 7E
TX: 09:16:39 7E A0 19 03 0F DC 3C 6F E6 E6 00 C0 01 C1 00 28 00 64 19 09 00 FF 07 00 9E 6A 7E
RX: 09:16:39 7E A0 13 0F 03 FC 93 9E E6 E7 00 C4 01 C1 00 12 00 01 8A A0 7E
Disconnecting from the meter.
TX: 09:16:39 7E A0 07 03 0F 53 20 7E 7E
RX: 09:16:39 7E A0 1E 0F 03 73 E3 69 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
This is clear. Randomization start interval (attribute #5) is not implemented to the meter and the meter returns UnavailableObject error. You can remove that and it's not read.
MNN
Thank you.
Thank you.
  • NnmIomcqcTDVWiDuCD
  • iRnseovnShdVWR…
  • HgGuaAJJjTLjzz…
  • HYpmSpMsbgNghuph
  • ocYOMgUlQIJbgMUiQdIn
