  3. Connectivity Issue With Clou CL710K22
connectivity issue with clou CL710K22
By tagmout , 9 October, 2020
Hi ,
I want to connect with clou via a 3G modem , but i receive the error message bellow :
GXDLMSDirector 8.2.2009.0801
Log created 13:44:58
13:45:06 Initializing Network connection.
System.Net.Sockets.SocketException (0x80004005): Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
Thank You in advance .
5 years 8 months ago
If you are using a dynamic IP address read this.
If you are using a static IP address check that there is no firewall that blocks the connection.
Check also that your TCP/IP port is correct.
