  3. Connectivity Issue
connectivity issue
By mohamadop , 17 September, 2020
Hi ,
I want to connect with the smart meter CLOU CL710K22 with IR cable but can't reach the meter .
Can you please check these device settings , and the logs below :
GXDLMSDirector 8.2.2009.0801
Log created 10:32:23
10:32:29 Initializing serial connection.
10:32:30 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
10:32:35 Data send failed. Try to resend 1/3
10:32:40 Data send failed. Try to resend 2/3
10:32:45 Failed to receive reply from the device in given time.
10:32:45 Disconnect request
10:32:45 Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
10:32:50 Data send failed. Try to resend 1/3
10:32:55 Data send failed. Try to resend 2/3
10:33:00 Failed to receive reply from the device in given time.
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
6 years ago
Try to set start protocol from DLMS to IEC if you are using an optical probe (IR cable).
Try also with different baud-rates.
mohamadop
6 years ago
Hi ,
Hi ,
It give me this error message with IEC and after changing baud-rate
6 years ago
Hi Mohamadop,
Hi Mohamadop,
There is no default device settings file for CLOU. Restart GXDLMSDirector. There is "New Manufacturer Settings Available" menu. Select it and update settings for CLOU. Create a new device and select "Shen Zhen Clou Electronics Co Ltd" as the manufacturer.
mohamadop
6 years ago
Thank You Mikko ,
Thank You Mikko ,
It's OK , I need the same for WASION .
6 years ago
Update the manufacturer settings and there are settings for WASION.
mohamadop
5 years 12 months ago
Hi Mikko ,
Hi Mikko ,
Settings for WASION still not exist .
You can see the manufacturer with an old name: Changsha Weisheng Electronics Ltd.
We'll update name to new one: Wasion Group Co.Ltd.
You can communicate with the old name at the moment.
mohamadop
Not working ,
Not working ,
It gives me the error message "failed to receive reply from the device in given time " with the devices properties bellow :
Change start protocol from IEC to DLMS. I don't know the baud rate, so you must try different compinations.
