IPV6 support for Listening Push Notification
14 posts / 0 new
Last post
deepaks
Do Director listen on IPV6 on TCP and UDP ?
Do Director supports Receiving Large Push Data Notification using GBT?
Thanks in advance !!!
Kurumi's picture
TCP/IP and UDP are supported for IPv4. I added IPv6 support for work list. It's on the next release.
GBT push messages are supported, but I'm not sure if any of our clients using them outside of the lab.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
deepaks
Thanks for the update, GBT now will be used out side lab to push the Block Load Profile as it will be big in size considering 15 minutes block duration and minimum 7-8 parameters.
Thanks and Regards
- Deepak Soni
- deepak.soni@securemeters.com
deepaks
Any updates on this?
Thanks in Advance !!!
Thanks and Regards
- Deepak Soni
Kurumi's picture
There has been some kind of misunderstanding.
The current version is supporting Push Data Notifications using GBT. If you have problems, can you post a trace from the messages that the meter sends so I can check them?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
deepaks
I would love to get the trace on my setup, but I could not as i am running my system on IPV6 which Gurux Director do not support. If you could provide me Director with true IPV6(Actual IPV6 address and not Temporary or Link Local) support i can proceed further and let you know the GBT traces...
Thanks and Regards
- Deepak Soni
Kurumi's picture
Support for IP v6 is added for GXDLMSDirector. The new version is released today.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
deepaks
I am using Gurux with latest Gurux Version 8.2.2010.0901 and Unable to run GBT, please find the log as follows:
Notifications listen started on Tcp port 4059.
Client connected: [2409:4050:f30:83::10]:4059
10/26/2020 11:58:11 AM
00 01 00 01 00 40 01 E9 E0 00 00 01 00 00 82 01 E0 0F B0 00 00 05 0C 07 E4 0A 1C 03 03 01 0B FF 80 00 00 02 04 0A 0D 45 48 4C 4C 49 42 35 30 30 31 30 30 34 09 06 00 06 19 09 00 FF 09 0C 07 E4 0A 1C 03 02 00 02 FF 80 00 00 01 30 02 12 09 0C 07 E4 0A 1B 02 02 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11
10/26/2020 11:58:12 AM
00 11 00 11 00 11 00 11 35 02 12 09 0C 07 E4 0A 1B 02 03 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 36 02 12 09 0C 07 E4 0A 1B 02 03 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 37 02 12 09 0C 07 E4 0A 1B 02 04 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 38 02 12 09 0C 07 E4 0A 1B 02 04 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 39 02 12 09 0C 07 E4 0A 1B 02 05 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3A 02 12 09 0C 07 E4 0A 1B 02 05 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3B 02 12 09 0C 07 E4 0A 1B 02 06 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3C 02 12 09 0C 07 E4 0A 1B 02 06 1E 00 FF 80 00 00 11 00 11 00 11
10/26/2020 11:58:21 AM
10/26/2020 11:58:22 AM
11 00 11 00 11 00 11 00 11 35 02 12 09 0C 07 E4 0A 1B 02 03 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 36 02 12 09 0C 07 E4 0A 1B 02 03 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 37 02 12 09 0C 07 E4 0A 1B 02 04 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 38 02 12 09 0C 07 E4 0A 1B 02 04 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 39 02 12 09 0C 07 E4 0A 1B 02 05 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3A 02 12 09 0C 07 E4 0A 1B 02 05 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3B 02 12 09 0C 07 E4 0A 1B 02 06 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3C 02 12 09 0C 07 E4 0A 1B 02 06 1E 00 FF 80 00 00 11 00 11 00 11
No GBT Ack is provided by Gurux.
Can you please suggest which piece i am missing, Is there any Pre-Condition?
Thanks in Advance
Thanks and Regards
- Deepak Soni
Kurumi's picture
Is your meter using Confirmed Push operation and not unconfirmed push?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
deepaks
Can you help how could i know about Confirmed or Unconfirmed services by some logs? What if i put window as 1 and streaming bit as 1 could be used for confirmed Services?
Please help
Thanks in Advance
Thanks and Regards
- Deepak Soni
BuiLy
Please let me know how to solve this matter ( in picture attach )
Thank you
Image:
BuiLy
Kurumi's picture
Hi BuiLy,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
deepaks
My meter is packing 2048 bytes of DataNotification APDU in General-Glo-Ciphering and then sends those using GBT to push Server.
Now as per Green Book to Meter has to send all the GBT blocks without expecting GBT Ack, Am I Right?
Thanks in Advance
Thanks and Regards
- Deepak Soni
Kurumi's picture
Meters are usually sending push messages without ACK (Unconfirmed service), but support for Confirmed services is added to Blue Book and then ACK is required. I don't know any meter that supports Confirmed Services at the moment.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
