  3. IPV6 Support For Listening Push Notification
IPV6 support for Listening Push Notification
By deepaks , 2 September, 2020
Do Director listen on IPV6 on TCP and UDP ?
Do Director supports Receiving Large Push Data Notification using GBT?
Thanks in advance !!!
6 years 2 months ago
TCP/IP and UDP are supported for IPv4. I added IPv6 support for work list. It's on the next release.
GBT push messages are supported, but I'm not sure if any of our clients using them outside of the lab.
deepaks
Thanks for the update, GBT now will be used out side lab to push the Block Load Profile as it will be big in size considering 15 minutes block duration and minimum 7-8 parameters.
deepaks
Any updates on this?
Thanks in Advance !!!
6 years 1 month ago
There has been some kind of misunderstanding.
The current version is supporting Push Data Notifications using GBT. If you have problems, can you post a trace from the messages that the meter sends so I can check them?
deepaks
6 years 1 month ago
I would love to get the trace on my setup, but I could not as i am running my system on IPV6 which Gurux Director do not support. If you could provide me Director with true IPV6(Actual IPV6 address and not Temporary or Link Local) support i can proceed further and let you know the GBT traces...
6 years 1 month ago
Support for IP v6 is added for GXDLMSDirector. The new version is released today.
deepaks
6 years ago
I am using Gurux with latest Gurux Version 8.2.2010.0901 and Unable to run GBT, please find the log as follows:
Notifications listen started on Tcp port 4059.
Client connected: [2409:4050:f30:83::10]:4059
10/26/2020 11:58:11 AM
00 01 00 01 00 40 01 E9 E0 00 00 01 00 00 82 01 E0 0F B0 00 00 05 0C 07 E4 0A 1C 03 03 01 0B FF 80 00 00 02 04 0A 0D 45 48 4C 4C 49 42 35 30 30 31 30 30 34 09 06 00 06 19 09 00 FF 09 0C 07 E4 0A 1C 03 02 00 02 FF 80 00 00 01 30 02 12 09 0C 07 E4 0A 1B 02 02 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11
10/26/2020 11:58:12 AM
00 11 00 11 00 11 00 11 35 02 12 09 0C 07 E4 0A 1B 02 03 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 36 02 12 09 0C 07 E4 0A 1B 02 03 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 37 02 12 09 0C 07 E4 0A 1B 02 04 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 38 02 12 09 0C 07 E4 0A 1B 02 04 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 39 02 12 09 0C 07 E4 0A 1B 02 05 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3A 02 12 09 0C 07 E4 0A 1B 02 05 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3B 02 12 09 0C 07 E4 0A 1B 02 06 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3C 02 12 09 0C 07 E4 0A 1B 02 06 1E 00 FF 80 00 00 11 00 11 00 11
10/26/2020 11:58:21 AM
10/26/2020 11:58:22 AM
11 00 11 00 11 00 11 00 11 35 02 12 09 0C 07 E4 0A 1B 02 03 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 36 02 12 09 0C 07 E4 0A 1B 02 03 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 37 02 12 09 0C 07 E4 0A 1B 02 04 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 38 02 12 09 0C 07 E4 0A 1B 02 04 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 39 02 12 09 0C 07 E4 0A 1B 02 05 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3A 02 12 09 0C 07 E4 0A 1B 02 05 1E 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3B 02 12 09 0C 07 E4 0A 1B 02 06 00 00 FF 80 00 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 00 11 3C 02 12 09 0C 07 E4 0A 1B 02 06 1E 00 FF 80 00 00 11 00 11 00 11
No GBT Ack is provided by Gurux.
Can you please suggest which piece i am missing, Is there any Pre-Condition?
Thanks in Advance
6 years ago
Is your meter using Confirmed Push operation and not unconfirmed push?
deepaks
6 years ago
Can you help how could i know about Confirmed or Unconfirmed services by some logs? What if i put window as 1 and streaming bit as 1 could be used for confirmed Services?
Please help
Thanks in Advance
BuiLy
6 years ago
Please let me know how to
Please let me know how to solve this matter ( in picture attach )
Thank you
deepaks
6 years ago
My meter is packing 2048 bytes of DataNotification APDU in General-Glo-Ciphering and then sends those using GBT to push Server.
Now as per Green Book to Meter has to send all the GBT blocks without expecting GBT Ack, Am I Right?
Thanks in Advance
6 years ago
Meters are usually sending push messages without ACK (Unconfirmed service), but support for Confirmed services is added to Blue Book and then ACK is required. I don't know any meter that supports Confirmed Services at the moment.
6 years ago
In reply to Please let me know how to by BuiLy
Hi BuiLy,
Hi BuiLy,
