  3. Elster AS1440
Elster AS1440
By mohamadop , 12 August, 2020
Hi Mikko ,
Can i read this meter with GXDLMSDirecto , You can find the attached datasheet .
6 years 1 month ago
DLMS/COSEM is available in option. If your meter is supporting DLMS, you can read it using GXDLMSDirector.
tagmout
6 years 1 month ago
Dlms /cosem is available in
Dlms /cosem is available in option , does mean it supports dlms ?
6 years 1 month ago
It means that you need to buy special version from the meter that supports DLMS. The normal meter doesn't support DLMS/COSEM.
tagmout
6 years 1 month ago
Ah okey , So with this one ,
Ah okey , So with this one , we can't read it with GXDLMSDirector ?
Thanks Mikko for your reactions .
6 years 1 month ago
I don't know what version you have. You need to ask this from the meter vendor is DLMS supported or not.
mohamadop
6 years 1 month ago
I can read it with alphaset
I can read it with alphaset software , You can see the log file , they communicate with which protocol ?
6 years 1 month ago
Your application is using IEC 62056-21.
I can't tell is your meter supporting DLMS or not.
