  3. Exception Error On Reading Objects
Exception Error on reading objects
By Palwinder , 8 June, 2020
Whenever I read any object I get an error 'ServiceError Read exception. Service Unsupported'
This is happening in HLS, LLS
What might be the problem ?
6 years 3 months ago
The reason for this is usually that your client address or authentication level is wrong. What is your GXDLMSDirector version?
Palwinder
Sorry I forget to add, that 'I am ABLE to connect the meter- It shows ready and connected'. It's just whenever I read any object I get the mentioned error.
The version I am using is 8.2.2006.0901
Can you open device settings and select "Supported Services" tab and check that "Get" service is selected?
Palwinder
Thankyou, the problem is
Thankyou, the problem is resolved !
Kind Regards
Palwinder
  • VigneshwaranC1993
  • Yousef Al-Saye…
  • Ask313
  • EmilioBecerra
  • Kundan Dhande
