  3. Not Receive Data Notification From Meter
Not receive data notification from meter
By Bhaumik , 21 January, 2020
I have set my PC's IPV6 address in push setup object.
When I push object list from GXDLMSDirector, I got message "Action Accomplish". Before that I have started Notification from menubar.
But there is no any notification shown in GXDLMSDirector.
How to get notification over notification window ?
Following are logs from GXDLMSDirector Trace View
<!--Decrypt data: C3 01 C1 00 28 00 00 19 09 00 FF 01 01 0F 00
<ActionRequest>
<ActionRequestNormal>
<MethodDescriptor>
<!--PushSetup-->
<ClassId Value="0028" />
<!--0.0.25.9.0.255-->
<InstanceId Value="0000190900FF" />
<MethodId Value="01" />
</MethodDescriptor>
<MethodInvocationParameters>
<Int8 Value="00" />
</MethodInvocationParameters>
</ActionRequestNormal>
</ActionRequest>
<glo_ActionRequest Value="3000000325BA7063186299F4D90289C0CF5A0A3280375631E0714EE5767C78D1" />
16:49:45
<glo_ActionResponse Value="3000000CB25B95563BD3DF09E71413EC1B8E55F9733B" />
6 years 8 months ago
"Action Accomplish" indicates that you have trigger the push notification.
You can start noifications right away before triggering the push event.
Is your meter sending Push messages to the TCP/IP server or for the client?
Note that push messages are shown on the Notification view.
Bhaumik
Meter sending Push messages to the TCP/IP server only. (I have started TCP listener on my PC.
In that also we are not able to seen any notifications.)
Check that meter address in Push object is the same as your PC.
Also make sure that meter can connect to your PC.
If your meter is communicating over the GPRS your PC address must be public
Bhaumik
Meter was not able to connect to my PC address due to private IPV6 assigned. Hence push notification was not received.
Using public address notification received successfully.
Thanks for support and suggestions.
6 years 7 months ago
Hi Bhaumik,
Hi Bhaumik,
Thank you for this info. I'm glad that this solved. Sometimes it might be a pain when messages are lost.
