  3. Secured Connection In Serial Java With Frame Counter
Secured Connection in Serial Java with Frame Counter
By Remith , 6 September, 2019
I am reading new type of L&T meter by setting BlockCipher ,AuthenticationKey
and Frame Counter LN. Its working in GXDLMSDirector.(Please check the
attached image)
But how to set this frame counter in Java application. I am unable to do this
as it accept only long value.
setFrameCounter(final long value).
But I want to set obiscode instead of long value. Old L&T meters are working
without security in java application.
Please explain me the logic.
7 years ago
You need to make a connection to the meter without authentication. Then read 0.0.43.1.1.255 data object.
Save value. Close the connection and update read value to FrameCounter. Then start a new connection using an encrypted connection.
GXDLMSData d = new GXDLMSData("0.0.43.1.1.255");
//Read value.
cl.setFrameCounter((long) d.getValue());
//Start ciphered connection.
Remith
7 years ago
As you said I have read the 0.0.43.1.2.255 and got one long value and in the next connection I used this long value for the frame counter authentication. Now I am getting the values but kwh value not getting. 1.0.1.8.0.255 value showing as invalid and giving only scalar like below.
-------- Reading GXDLMSRegister 1.0.1.8.0.255 Invalid
Index: 3 Value: Scaler: 10 Unit: ActiveEnergy
-------- Reading GXDLMSRegister 1.0.2.8.0.255 Invalid
I am not able to attach log and trace.
Please share your email so that I can send it you.
Thanks...
REMITH
7 years ago
Hi REMITH,
Hi REMITH,
Can you read them with GXDLMSDirector? Are you using the same client address and password?
Remith
7 years ago
Hi, in GXDLMSDirector also
Hi, in GXDLMSDirector also same thing.
Anyway your above logic to read frame counter is working fine. Anyway I have completed with
direct reading with GXDLMSRegister("0.0.43.1.2.255 "); concept.
Thanks for your great support.
Remith
7 years ago
