Hello. I'm new with Gurux and Meter devices.
I'm doing some tests about access to Meter OBISs using DLMS\COSEM protocol, with GXDLMSDirector, but I have different behaviours with different version of this software or GURUX library.
I tried to read Unix Data OBIS and with the last version of the GXDLMSDirector software I cannot do it, the error is the seguent:
in GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply) in C:\00-LAVORO\CAVAGNAGROUP\SVILUPPO-GIT\IOT\Gurux\GXDLMSDirector-OldVersion-OK\GXDLMSDirector-master\Development\GXDLMSCommunicator.cs:riga 374
in GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply) in C:\00-LAVORO\CAVAGNAGROUP\SVILUPPO-GIT\IOT\Gurux\GXDLMSDirector-OldVersion-OK\GXDLMSDirector-master\Development\GXDLMSCommunicator.cs:riga 1186
in GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, GXReplyData reply) in C:\00-LAVORO\CAVAGNAGROUP\SVILUPPO-GIT\IOT\Gurux\GXDLMSDirector-OldVersion-OK\GXDLMSDirector-master\Development\GXDLMSCommunicator.cs:riga 1168
in GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, GXReplyData reply) in C:\00-LAVORO\CAVAGNAGROUP\SVILUPPO-GIT\IOT\Gurux\GXDLMSDirector-OldVersion-OK\GXDLMSDirector-master\Development\GXDLMSCommunicator.cs:riga 1113
in GXDLMSDirector.GXDLMSCommunicator.KeepAlive() in C:\00-LAVORO\CAVAGNAGROUP\SVILUPPO-GIT\IOT\Gurux\GXDLMSDirector-OldVersion-OK\GXDLMSDirector-master\Development\GXDLMSCommunicator.cs:riga 1598
in GXDLMSDirector.GXDLMSDevice.KeepAlive_Elapsed(Object sender, ElapsedEventArgs e) in C:\00-LAVORO\CAVAGNAGROUP\SVILUPPO-GIT\IOT\Gurux\GXDLMSDirector-OldVersion-OK\GXDLMSDirector-master\Development\GXDLMSDevice.cs:riga 757
I'm looking for ad old version of the software and It's able to read all Meter OBISs.
Why there are so many differences between different versions?
Are there specific software configuration to set for works with every versions?
Hello. Thanks for you support.
This is the text log: see below.
I cannot understand if there are configuration troubles or incompatibility between our meter firmware and the last Gurux version (I hope it's impossible ...).
Really thankyou for the support!!!
Log created 17:22:59
17:24:38 Initializing serial connection.
17:24:42 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
17:24:42
7E A0 0C 03 03 73 97 36 81 80 00 8B 15 7E
17:24:42 Parsing UA reply succeeded.
17:24:48 Read object type Data index: 2
7E A0 35 03 03 32 8B D0 E6 E6 00 DB 08 53 41 43 53 41 43 53 41 1E 30 00 00 00 01 D3 9D D6 A2 8B 50 C8 44 E6 9C BA DA 1F 6A 84 0B 59 0F 11 15 1C 6C 93 42 10 F5 97 7E
17:24:50 Data send failed. Try to resend 1/3
17:24:53 Data send failed. Try to resend 2/3
17:24:55 Failed to receive reply from the device in given time.
7E A0 09 03 03 11 D4 18 7E 7E A0 09 03 03 11 D4 18 7E 7E A0 09 03 03 11 D4 18 7E
17:24:55 Received data:
in GXDLMSDirector.GXDLMSCommunicator.Read(Object sender, GXDLMSObject obj, Boolean forceRead) in C:\SOLUTION_PATH\GXDLMSCommunicator.cs:riga 1452
in GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters) in C:\SOLUTION_PATH\MainForm.cs:riga 2120
17:26:39 Read object type Data index: 2
7E A0 35 03 03 54 BB D6 E6 E6 00 DB 08 53 41 43 53 41 43 53 41 1E 30 00 00 00 02 71 52 16 3E A3 69 DB 5E DA 3C 6E 5A C3 65 31 18 B9 17 D2 4C 53 22 5C BA EE 4C FB 7E
17:29:50 Data send failed. Try to resend 1/2
17:33:04 Failed to receive reply from the device in given time.
17:34:54 Send Keep Alive
7E A0 35 03 03 76 AB D4 E6 E6 00 DB 08 53 41 43 53 41 43 53 41 1E 30 00 00 00 03 E6 33 20 03 4F D1 ED 2C 17 C7 4B 3D 1B 2F CA 39 01 1F D1 E2 9E 4E E6 AD A0 4D 08 7E
17:34:56 Data send failed. Try to resend 1/2
17:34:58 Failed to receive reply from the device in given time.
17:34:58 Disconnect request
7E A0 07 03 03 53 80 D7 7E
17:35:00 Data send failed. Try to resend 1/2
17:35:02 Failed to receive reply from the device in given time.
in GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply) in C:\SOLUTION_PATH\GXDLMSCommunicator.cs:riga 305
in GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply) in C:\SOLUTION_PATH\GXDLMSCommunicator.cs:riga 1186
in GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, GXReplyData reply) in C:\SOLUTION_PATH\GXDLMSCommunicator.cs:riga 1168
in GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, GXReplyData reply) in C:\SOLUTION_PATH\GXDLMSCommunicator.cs:riga 1113
in GXDLMSDirector.GXDLMSCommunicator.KeepAlive() in C:\SOLUTION_PATH\GXDLMSCommunicator.cs:riga 1598
in GXDLMSDirector.GXDLMSDevice.KeepAlive_Elapsed(Object sender, ElapsedEventArgs e) in C:\SOLUTION_PATH\GXDLMSDevice.cs:riga 757
17:37:08 Initializing serial connection.
17:37:11 Send SNRM request.
17:37:13 Failed to receive reply from the device in given time.
17:37:13 Disconnect request
17:37:13 Send Disconnect request.
17:37:15 Failed to receive reply from the device in given time.
in GXDLMSDirector.GXDLMSDevice.InitializeConnection() in C:\SOLUTION_PATH\GXDLMSDevice.cs:riga 183
in GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters) in C:\SOLUTION_PATH\MainForm.cs:riga 1328
17:37:49 Initializing serial connection.
17:37:52 Send SNRM request.
17:37:52
17:37:52 Parsing UA reply succeeded.
17:37:59 Read object type Data index: 2
17:38:01 Data send failed. Try to resend 1/3
17:38:03 Data send failed. Try to resend 2/3
17:38:05 Failed to receive reply from the device in given time.
17:38:05 Received data:
17:39:16 Read object type Data index: 2
17:41:18 Data send failed. Try to resend 1/2
17:41:36 Failed to receive reply from the device in given time.
Have you made any changes for the source codes? You are using a ciphered (encrypted) connection? Can you send trace from old version so I can compare with that.
This is the trace about a correct trasmission, obtained with an old version of the GXDLMSDirector.
After the trace, you can find all library version used by GXDLMSDirector.
GXDLMSDirector 0.0.0.0
Log created 11:49:36
11:50:20 Initializing serial connection.
11:50:20 Send SNRM request.
11:50:20
11:50:20 Parsing UA reply succeeded.
11:50:25 Read object type Data index: 2
7E A0 35 03 03 10 9B D2 E6 E6 00 DB 08 53 41 43 53 41 43 53 41 1E 30 00 00 00 01 D3 9D D6 A2 8B 50 C8 44 E6 9C BA DA 1F 6A 84 0B 59 0F 11 15 1C 6C 93 42 10 F5 97 7E
11:50:25
7E A0 29 03 03 30 0C A7 E6 E7 00 DB 00 1A 30 00 00 00 01 80 56 9D CF FB 9C 3E 55 33 66 83 BA 1C CD 2C 50 2F B9 92 AE 41 67 C4 7E
I didn't change the source code: I only debugged the Gurux source code project and the DLMXDirector source code project for better understand the protocol.
Thanks.
I believe that "General Protection" is not selected. Can you select device settings and select "Supported services" tab. "General Protection" should be checked.
Can you send your image as a log? I'll check this, but I need a log.
17:24:42
17:37:52
Of course:
Of course:
11:50:20
11:50:25
Library Version:
.NET Framework 3.5 SP 1 3.5.30729.4926
.NET Framework 4.0 4.8.03752
---GURUX--- -----
GXDLMSDirector.exe 0.0.0.0
---MICROSOFT--- -----
ntdll.dll 10.0.18362.290 (WinBuild.160101.0800)
MSCOREE.DLL 10.0.18362.1 (WinBuild.160101.0800)
KERNEL32.dll 10.0.18362.290 (WinBuild.160101.0800)
KERNELBASE.dll 10.0.18362.290 (WinBuild.160101.0800)
ADVAPI32.dll 10.0.18362.290 (WinBuild.160101.0800)
msvcrt.dll 7.0.18362.1 (WinBuild.160101.0800)
sechost.dll 10.0.18362.1 (WinBuild.160101.0800)
RPCRT4.dll 10.0.18362.290 (WinBuild.160101.0800)
mscoreei.dll 4.8.3752.0 built by: NET48REL1
SHLWAPI.dll 10.0.18362.290 (WinBuild.160101.0800)
combase.dll 10.0.18362.290 (WinBuild.160101.0800)
ucrtbase.dll 10.0.18362.1 (WinBuild.160101.0800)
bcryptPrimitives.dll 10.0.18362.239 (WinBuild.160101.0800)
GDI32.dll 10.0.18362.1 (WinBuild.160101.0800)
win32u.dll 10.0.18362.239 (WinBuild.160101.0800)
gdi32full.dll 10.0.18362.239 (WinBuild.160101.0800)
msvcp_win.dll 10.0.18362.1 (WinBuild.160101.0800)
USER32.dll 10.0.18362.290 (WinBuild.160101.0800)
IMM32.DLL 10.0.18362.1 (WinBuild.160101.0800)
kernel.appcore.dll 10.0.18362.1 (WinBuild.160101.0800)
VERSION.dll 10.0.18362.1 (WinBuild.160101.0800)
clr.dll 4.8.3815.0 built by: NET48REL1LAST_C
VCRUNTIME140_CLR0400.dll 14.10.25028.0 built by: VCTOOLSD15RTM
ucrtbase_clr0400.dll 14.10.25028.0 built by: VCTOOLSD15RTM
psapi.dll 10.0.18362.1 (WinBuild.160101.0800)
mscorlib.ni.dll 4.8.3815.0 built by: NET48REL1LAST_C
ole32.dll 10.0.18362.290 (WinBuild.160101.0800)
uxtheme.dll 10.0.18362.290 (WinBuild.160101.0800)
clrjit.dll 4.8.3815.0 built by: NET48REL1LAST_C
System.ni.dll 4.8.3801.0 built by: NET48REL1LAST_B
System.Drawing.ni.dll 4.8.3752.0 built by: NET48REL1
System.Windows.Forms.ni.dll 4.8.3815.0 built by: NET48REL1LAST_C
System.Core.ni.dll 4.8.3815.0 built by: NET48REL1LAST_C
System.Configuration.ni.dll 4.8.3752.0 built by: NET48REL1
urlmon.dll 11.00.18362.290 (WinBuild.160101.0800)
shcore.dll 10.0.18362.290 (WinBuild.160101.0800)
iertutil.dll 11.00.18362.290 (WinBuild.160101.0800)
windows.storage.dll 10.0.18362.290 (WinBuild.160101.0800)
profapi.dll 10.0.18362.1 (WinBuild.160101.0800)
powrprof.dll 10.0.18362.290 (WinBuild.160101.0800)
CRYPTBASE.DLL 10.0.18362.1 (WinBuild.160101.0800)
SspiCli.dll 10.0.18362.1 (WinBuild.160101.0800)
PROPSYS.dll 7.0.18362.290 (WinBuild.160101.0800)
OLEAUT32.dll 10.0.18362.86 (WinBuild.160101.0800)
CRYPTSP.dll 10.0.18362.1 (WinBuild.160101.0800)
rsaenh.dll 10.0.18362.1 (WinBuild.160101.0800)
bcrypt.dll 10.0.18362.290 (WinBuild.160101.0800)
shell32.dll 10.0.18362.290 (WinBuild.160101.0800)
cfgmgr32.dll 10.0.18362.1 (WinBuild.160101.0800)
System.Xml.ni.dll 4.8.3752.0 built by: NET48REL1
System.Deployment.ni.dll 4.8.3752.0 built by: NET48REL1
comctl32.dll 6.10 (WinBuild.160101.0800)
MSCTF.dll 10.0.18362.290 (WinBuild.160101.0800)
gdiplus.dll 10.0.18362.239 (WinBuild.160101.0800)
DWrite.dll 10.0.18362.290 (WinBuild.160101.0800)
WindowsCodecs.dll 10.0.18362.1 (WinBuild.160101.0800)
System.Data.ni.dll 4.8.3752.0 built by: NET48REL1
System.Data.dll 4.8.3752.0 built by: NET48REL1
WS2_32.dll 10.0.18362.290 (WinBuild.160101.0800)
CRYPT32.dll 10.0.18362.290 (WinBuild.160101.0800)
MSASN1.dll 10.0.18362.1 (WinBuild.160101.0800)
wininet.dll 11.00.18362.290 (WinBuild.160101.0800)
ondemandconnroutehelper.dll 10.0.18362.1 (WinBuild.160101.0800)
winhttp.dll 10.0.18362.290 (WinBuild.160101.0800)
IPHLPAPI.DLL 10.0.18362.290 (WinBuild.160101.0800)
mswsock.dll 10.0.18362.290 (WinBuild.160101.0800)
NSI.dll 10.0.18362.1 (WinBuild.160101.0800)
WINNSI.DLL 10.0.18362.1 (WinBuild.160101.0800)
TextInputFramework.dll 10.0.18362.207 (WinBuild.160101.0800)
CoreUIComponents.dll 10.0.18362.207
CoreMessaging.dll 10.0.18362.1
wintypes.dll 10.0.18362.290 (WinBuild.160101.0800)
ntmarta.dll 10.0.18362.290 (WinBuild.160101.0800)
rasapi32.dll 10.0.18362.290 (WinBuild.160101.0800)
rasman.dll 10.0.18362.1 (WinBuild.160101.0800)
rtutils.dll 10.0.18362.1 (WinBuild.160101.0800)
dhcpcsvc6.DLL 10.0.18362.290 (WinBuild.160101.0800)
dhcpcsvc.DLL 10.0.18362.290 (WinBuild.160101.0800)
DNSAPI.dll 10.0.18362.290 (WinBuild.160101.0800)
rasadhlp.dll 10.0.18362.1 (WinBuild.160101.0800)
fwpuclnt.dll 10.0.18362.290 (WinBuild.160101.0800)
clbcatq.dll 2001.12.10941.16384 (WinBuild.160101.0800)
comdlg32.dll 10.0.18362.290 (WinBuild.160101.0800)
DUI70.dll 10.0.18362.290 (WinBuild.160101.0800)
DUser.dll 10.0.18362.290 (WinBuild.160101.0800)
dwmapi.dll 10.0.18362.290 (WinBuild.160101.0800)
tiptsf.dll 10.0.18362.290 (WinBuild.160101.0800)
edputil.dll 10.0.18362.290 (WinBuild.160101.0800)
explorerframe.dll 10.0.18362.290 (WinBuild.160101.0800)
thumbcache.dll 10.0.18362.290 (WinBuild.160101.0800)
dataexchange.dll 10.0.18362.1 (WinBuild.160101.0800)
d3d11.dll 10.0.18362.1 (WinBuild.160101.0800)
dcomp.dll 10.0.18362.145 (WinBuild.160101.0800)
dxgi.dll 10.0.18362.145 (WinBuild.160101.0800)
dxcore.dll 10.0.18362.1 (WinBuild.160101.0800)
twinapi.appcore.dll 10.0.18362.290 (WinBuild.160101.0800)
RMCLIENT.dll 10.0.18362.1 (WinBuild.160101.0800)
Windows.Globalization.dll 10.0.18362.1 (WinBuild.160101.0800)
Bcp47Langs.dll 10.0.18362.1 (WinBuild.160101.0800)
bcp47mrm.dll 10.0.18362.1 (WinBuild.160101.0800)
globinputhost.dll 10.0.18362.1 (WinBuild.160101.0800)
StructuredQuery.dll 7.0.18362.1 (WinBuild.160101.0800)
atlthunk.dll 10.0.18362.1 (WinBuild.160101.0800)
Windows.StateRepositoryPS.dll 10.0.18362.1 (WinBuild.160101.0800)
Windows.Storage.Search.dll 10.0.18362.290 (WinBuild.160101.0800)
LINKINFO.dll 10.0.18362.1 (WinBuild.160101.0800)
ntshrui.dll 10.0.18362.290 (WinBuild.160101.0800)
srvcli.dll 10.0.18362.1 (WinBuild.160101.0800)
cscapi.dll 10.0.18362.1 (WinBuild.160101.0800)
CLDAPI.dll 10.0.18362.1 (WinBuild.160101.0800)
FLTLIB.DLL 10.0.18362.290 (WinBuild.160101.0800)
coml2.dll 10.0.18362.1 (WinBuild.160101.0800)
MPR.dll 10.0.18362.290 (WinBuild.160101.0800)
drprov.dll 10.0.18362.290 (WinBuild.160101.0800)
WINSTA.dll 10.0.18362.53 (WinBuild.160101.0800)
ntlanman.dll 10.0.18362.290 (WinBuild.160101.0800)
davclnt.dll 10.0.18362.1 (WinBuild.160101.0800)
DAVHLPR.dll 10.0.18362.1 (WinBuild.160101.0800)
wkscli.dll 10.0.18362.1 (WinBuild.160101.0800)
netutils.dll 10.0.18362.1 (WinBuild.160101.0800)
twinapi.dll 10.0.18362.290 (WinBuild.160101.0800)
apphelp.dll 10.0.18362.290 (WinBuild.160101.0800)
dlnashext.dll 10.0.18362.290 (WinBuild.160101.0800)
PlayToDevice.dll 10.0.18362.290 (WinBuild.160101.0800)
DevDispItemProvider.dll 10.0.18362.290 (WinBuild.160101.0800)
WINMM.dll 10.0.18362.290 (WinBuild.160101.0800)
winmmbase.dll 10.0.18362.1 (WinBuild.160101.0800)
ActXPrxy.dll 10.0.18362.1 (WinBuild.160101.0800)
MSVCP140.dll 14.10.25008.0 built by: VCTOOLSD15RTM
VCRUNTIME140.dll 14.10.25008.0 built by: VCTOOLSD15RTM
Secur32.dll 10.0.18362.1 (WinBuild.160101.0800)
WLDAP32.dll 10.0.18362.290 (WinBuild.160101.0800)
MMDevApi.dll 10.0.18362.290 (WinBuild.160101.0800)
DEVOBJ.dll 10.0.18362.1 (WinBuild.160101.0800)
FileSyncShell64.dll 19.103.0527.0003
USERENV.dll 10.0.18362.290 (WinBuild.160101.0800)
WTSAPI32.dll 10.0.18362.1 (WinBuild.160101.0800)
ktmw32.dll 10.0.18362.1 (WinBuild.160101.0800)
PortableDeviceApi.dll 10.0.18362.290 (WinBuild.160101.0800)
SETUPAPI.dll 10.0.18362.290 (WinBuild.160101.0800)
WINTRUST.dll 10.0.18362.145 (WinBuild.160101.0800)
PortableDeviceTypes.dll 10.0.18362.1 (WinBuild.160101.0800)
policymanager.dll 10.0.18362.1 (WinBuild.160101.0800)
msvcp110_win.dll 10.0.18362.1 (WinBuild.160101.0800)
NetworkExplorer.dll 10.0.18362.290 (WinBuild.160101.0800)
EhStorShell.dll 10.0.18362.290 (WinBuild.160101.0800)
GROOVEEX.DLL 16.0.4711.1000
EhStorAPI.dll 10.0.18362.290 (WinBuild.160101.0800)
msi.dll 5.0.18362.207
GrooveIntlResource.dll 16.0.4507.1000
cscui.dll 10.0.18362.290 (WinBuild.160101.0800)
sxs.dll 10.0.18362.290 (WinBuild.160101.0800)
dfshim.dll 10.0.18362.1 (WinBuild.160101.0800)
dfdll.dll 4.8.3752.0 built by: NET48REL1
wldp.dll 10.0.18362.290 (WinBuild.160101.0800)
amsi.dll 10.0.18362.1 (WinBuild.160101.0800)
---OTHERS--- -----
UMPDC.dll
TortoiseOverlays.dll 1, 1, 4, 26626
TortoiseStub.dll 1.12.0.28568
TortoiseSVN.dll 1.12.0.28568
libsvn_tsvn.dll 1.12.0
libapr_tsvn.dll 1.6.5
intl3_tsvn.dll 0.14.6
libaprutil_tsvn.dll 1.6.1
libsasl.dll 2.1.24
amsi_plugin64.dll.e9bffbee5e89efbe274fe1573f1f6966 2.4.0.86
Thanks.
MatteoS
Hi Matteo,
Hi Matteo,
