HDLC frame is described on the standard. Its value is changed all the time. I believe that the best and fastest way is if you use our open source libraries to read your meter.
DLMS is a complicated protocol and the control frame is part of HDLC framing.
It's not possible to describe shortly. You need the "IEC 62056-46 Data link layer using HDLC protocol" standard to handle the HDLC frames.
How can i make control field one byte hex value?????
not need to use your library…
not need to use your library just share how we make control frame for any hex string?
Hi, DLMS is a complicated…
https://gurux.fi/DLMSCOSEMFAQ
