  2. Support For Gateway Protocol Added.
Support for gateway protocol added.
By Kurumi , 13 June, 2018
Project
Gurux.DLMS.Net
Status
Closed (fixed)
Priority
Normal
Category
Feature request
vinayak
8 years 4 months ago
will it works with windows
will it works with windows plattform
Hi vinayak,
Client side will work. I'm just designing how to include this to the server side.
vinayak
8 years 3 months ago
changing hdlc address
Using obis code 1.0.0.0.3.255 in gurux, I'm not able to change the default value 256 to other values.
Gurux is showing read/write access for that data object, but still i am not able to write a value.
Same have been done using meter's manufacturer software. Please help in this issue.
meter used: Microstar P2000-T
Hi vinayak,
If you have a question as it on the Forum. Don't create an issue.
alaa dwikat
5 years 11 months ago
Gateway
Hello, I am wondering how to use gateway (concentrator) in reading meter with c#, and if I can read multiple meters simultaneously through a gateway?
If you have a question as it on the Forum. Don't create an issue. Also if you have a new question create a new topic.
