  3. PPP Setup
gxdn
By Administrator , 23 January, 2018
PPP setup object is used to define the PPP settings.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. PHY reference
    Logical Name of physical layer.
  • 3. LCP options
    LCP configuration options.
  • 4.IPCP options
    IP Control Protocol options.
  • 5. PPP authentication
    PPP authentication parameters.
Actions
There are no actions available for this object type.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
