  3. Single Action Schedule
gxdn
By Administrator , 23 January, 2018
Single action schedule object is used to execute selected script in given time.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Executed script
    Script to execute.
  • 3. Type
    Execution type.
  • 4. Execution time
    List of script execution times.
    Note! Time zone or Daylight Saving Time info is not send in part of the execution time. Some meters are executing this using meter's time and some as EPOCH time.
Actions
There are no actions available for this object type.
Access data from ANSI C
  • Initialize
  • Show
//Add new action schedule.
unsigned char target[6] = { 0, 1, 10, 1, 101,255 };
gxtime* tm;
const unsigned char ln[6] = { 0,0,15,0,0,255 };
cosem_init2((gxObject*)&actionSchedule, DLMS_OBJECT_TYPE_ACTION_SCHEDULE, ln);
memcpy(actionSchedule.executedScriptLogicalName, target, 6);
actionSchedule.executedScriptSelector = 1;
actionSchedule.type = DLMS_SINGLE_ACTION_SCHEDULE_TYPE1;
//Add new execution time to the list.
tm = (gxtime*)malloc(sizeof(gxtime));
time_now(tm);
arr_push(&actionSchedule.executionTime, tm);
//How to access action schedule data.
int pos = 0, ret;
gxtime* tm;
hlp_printLogicalName("Name: %s\r\n", object->executedScriptLogicalName);
printf("Executed Script Selector: %d\n",object->executedScriptSelector);
printf("Type: %d\n", object->type);
for (pos = 0; pos != object->executionTime.size; ++pos)
  ret = arr_getByIndex(&object->executionTime, pos, (void**)&tm);
    break;
  time_print(tm);
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
