  3. Register Table
gxdn
By Administrator , 23 January, 2018
Register table object is used to group homogeneous entries.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Table cell values
    Array of the captured attributes ,
  • 3. Table cell definition
    Array of captured register object and attribute index pairs.
  • 4. Scaler and unit.
    Used unit and the scaler of the value.
Actions
  • 1. Reset
    This action is used to reset value to default value.
  • 2. Capture
    Copies the target values to the table cell values list
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
