  3. Extended Register
gxdn
By Administrator , 23 January, 2018
Extended register object is used to save value with its associated scaler, unit, status and capture.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Value
    Value of data object. Value type can be any kind of value type described on DLMS standard.
  • 3. Scaler and unit
    Used unit and the scaler of the value.
  • 4. Status
    Status information. Value of the status is depending from the object instance Logical Name.
  • 5. Capture time
    Capture time.
Actions
  • 1. Reset
    This action is used to reset value to default value. Note! There is no default value and for this reason meter must handle this in preAction or postAction. This value is clear by default.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
