  3. Manufacturer Settings File
Manufacturer Settings file
By mklalos , 12 January, 2016
The DLMS Client App is using a file including the manufacturer settings. However, i don't know where I can download that file from. Can anybody help me? Thanks in advance.
Miguel
10 years 9 months ago
You can download it running example with /u parameter.
Get latest version from GitHub.
https://github.com/gurux
mklalos
Got it. Thanks.
jbeltran
10 years 8 months ago
I failed to update using /u for the DLMS Client App to get the Manufacturer (Elster) using below arguments
/m=ele /h=www.gurux.org /p=1000 /u
AND
/m=ele /h=www.gurux.fi /p=1000 /u
Please help, I need Manufacturer settings file for Elster
In reply to Manufacturer Settings file by jbeltran
Elster
Parameters for your meter reading are:
/m=ele /h=Your meter IP /p=Your meter port
jbeltran
If you need to get Manufacturer settings using Serial Connection, what are the possible parameters that go with /u ?
Thank you in advance.
10 years 7 months ago
/u parameter retrieves available manufacturer settings from Gurux server.
You only need to do it once.
After that just go with oarameters;
/m=ele /sp=Your serial port /t
marco_semax
In reply to Manufacturer settings by Kurumi
I had the also a problem with
I had also a problem with the settings. I am working with Elster modules, they use ELS-...... not ELE-.....
After I changed that I was working
I checked this and it seems that there are four different FLAG name that Elster might use.
http://dlms.com/organization/flagmanufacturesids/index.html
We have to think about this. Easy way is create several manufacturer settings using ELE, ELS, etc,
but it is not nice to select new meter manufacturer from the list where name is almost same.
jbeltran
Harding Manufacturing settings
If I am to hardcode the Manufacturer settings for testing only. What are the parameters that are important? Thank you for the reply.
There are frou important parameters.
Is used Short or Logican Name referencing
Server address
Client Address
Interface type (HDLC or wrapper)
zz
sorry - mistake
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
