  3. Generic Exception Raised On HLS Authentication Failure Instead of GXDLMSException
Generic Exception raised on HLS authentication failure instead of GXDLMSException
By eriktrif , 26 August, 2026
Gurux DLMS for Python
GXDLMSClient.py:
Current code:
if not equals:
    raise Exception(
        "parseApplicationAssociationResponse failed. "
        + " Server to Client do not match."
Should be:
# In GXDLMSClient.py imports:
from .GXDLMSException import GXDLMSException
from .enums import AssociationResult  # (add to existing 'from .enums import ...')
# In parseApplicationAssociationResponse():
if not equals:
    raise GXDLMSException(
        AssociationResult.PERMANENT_REJECTED,
        SourceDiagnostic.AUTHENTICATION_FAILURE,
Reason:
When HLS authentication fails, parseApplicationAssociationResponse() raises a raw Python Exception instead of a typed GXDLMSException.
This causes several issues:
1. Dead code in GXDLMSReader.initializeConnection():
In GXDLMSReader.py, HLS authentication is wrapped in:
try:
    for it in self.client.getApplicationAssociationRequest():
        self.readDLMSPacket(it, reply)
    self.client.parseApplicationAssociationResponse(reply.data)
except GXDLMSException as ex:
    #Invalid password.
    raise GXDLMSException(AssociationResult.PERMANENT_REJECTED, SourceDiagnostic.AUTHENTICATION_FAILURE)
Because parseApplicationAssociationResponse() raises a base Exception (which does not inherit from GXDLMSException), the except GXDLMSException handler is never reached.
2. Inconsistency between LLS and HLS:
For LLS, authentication failure in parseAareResponse() raises GXDLMSException with:
HLS authentication failure should produce the same typed exception with the corresponding association error and diagnostic values.
3. Broken error handling for client applications:
Callers cannot inspect structured error attributes (result, diagnostic, errorCode) and are forced to catch generic Exception and parse the error string.
eriktrif
1 month 3 weeks ago
Hi I'm sorry! I accidentally…
Hi I'm sorry! I accidentally created this thread on the forum instead of in the bug tracker.
1 month 3 weeks ago
Hi, It's always better to…
It's always better to talk in the forum first than to create a bug report. Especially in a case like this.
initializeConnection exception handling solves a different problem. Some meters reply with all kinds of errors, and this handles that case.
I really understand your idea, but I need to verify with the customers whether using AUTHENTICATION_FAILURE will cause problems or if there are other problems it might cause.
