  3. Unable To Connect With Python, But I Can With GXDLMSDirector
Unable to connect with Python, but I can with GXDLMSDirector
By mick93 , 11 February, 2025
Hi, I am using meter, which is not on manufacturers (ZPA meter) list, so I added it manually. It uses HighGMAC with keys and certs. I really struggled to make it connect with the meter by GXDLMSDirector app, but I somehow managed to make it work. But after I tried it with python code, it's unable to read anything and disconnects with "Connection is permanently rejected"/"No reason is given.". Below is data after launching python code:
gurux_dlms version: 1.0.173
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
Authentication: 5
ClientAddress: 0x1
Standard: 0
Security: 48
System title: 43 54 54 30 30 30 30 30
Authentication key: xxx
Block cipher key: xxx
TX: 08:11:59 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 7E 1D FF FF
Data length is 43and there are 44 bytes.
RX: 08:12:00 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 3C 1D 07 D0 00 07 00
TX: 08:12:00 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 01 FF 02 00
Data length is 9and there are 10 bytes.
RX: 08:12:01 00 01 00 01 00 10 00 09 C4 01 C1 00 06 00 02 8F A9 00
Invocation counter: 167850
TX: 08:12:01 00 01 00 10 00 01 00 09 62 03 80 01 00 03 80 01 00
Data length is 5and there are 6 bytes.
RX: 08:12:02 00 01 00 01 00 10 00 05 63 03 80 01 00 00
TX: 08:12:02 00 01 00 01 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 43 54 54 30 30 30 30 30 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 29 E6 F0 D6 58 5B 41 76 F1 17 CF EE 84 7F 8A 34 BE 23 04 21 21 1F 30 00 02 8F AA 1B 03 BA 06 9B 43 C2 6F A9 2D 73 9D 9C 45 54 CD CA 95 D5 A1 BC 86 2E C6 55 43
Data length is 107and there are 108 bytes.
RX: 08:12:03 00 01 00 01 00 01 00 6B 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 5A 50 41 00 3B 9C 25 32 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 32 89 D6 2E 4E C5 B2 90 6A B4 A5 4D 2E 80 39 AF BE 23 04 21 28 1F 32 00 02 98 A7 E2 FF A4 FA 91 27 8E B1 9C F5 DB E7 5D 2E 9C AB 7B 16 3A 3F DF B6 50 CB 02 34 00
No reason is given.
And below is this data, but translated:
1) 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 7E 1D FF FF
2) 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 3C 1D 07 D0 00 07 00
TRANSLATE:
1: 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 7E 1D FF FF
<WRAPPER len="1F" >
<SourceAddress Value="10" />
<TargetAddress Value="1" />
<PDU>
<AssociationRequest>
<InitiateRequest>
<ProposedConformance>
<ConformanceBit Name="PriorityMgmtSupported" />
<ConformanceBit Name="Attribute0SupportedWithGet" />
<ConformanceBit Name="Get" />
<ConformanceBit Name="Set" />
</ProposedConformance>
</InitiateRequest>
</AssociationRequest>
</PDU>
</WRAPPER>
2: 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 3C 1D 07 D0 00 07
<WRAPPER len="2B" >
<SourceAddress Value="1" />
<TargetAddress Value="10" />
<PDU>
<AssociationResponse>
<AssociationResult Value="00" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="00" />
</ResultSourceDiagnostic>
<InitiateResponse>
<NegotiatedConformance>
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="07D0" />
<VaaName Value="0007" />
</InitiateResponse>
</AssociationResponse>
</PDU>
</WRAPPER>
1) 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 01 FF 02 00
2) 00 01 00 01 00 10 00 09 C4 01 C1 00 06 00 02 8F A9 00
TRANSLATED:
1: 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 01 FF 02 00
<WRAPPER len="D" >
<PDU>
<GetRequest>
<GetRequestNormal>
<!-- Priority: High, ServiceClass: Confirmed, Invoke ID: 1 -->
<AttributeDescriptor>
<!-- Data -->
<ClassId Value="0001" />
<!-- 0.0.43.1.1.255 -->
<InstanceId Value="00002B0101FF" />
<!-- Value -->
<AttributeId Value="02" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
</PDU>
</WRAPPER>
2: 00 01 00 01 00 10 00 09 C4 01 C1 00 06 00 02 8F A9
<WRAPPER len="9" >
<PDU>
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<UInt32 Value="00028FA9" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
</PDU>
</WRAPPER>
1) 00 01 00 10 00 01 00 09 62 03 80 01 00 03 80 01 00
2) 00 01 00 01 00 10 00 05 63 03 80 01 00 00
TRANSLATED:
1: 00 01 00 10 00 01 00 09 62 03 80 01 00 03 80 01 00
<WRAPPER len="9" >
<PDU>
<ReleaseRequest>
<Reason Value="Normal" />
</ReleaseRequest>
</PDU>
</WRAPPER>
2: 00 01 00 01 00 10 00 05 63 03 80 01 00
<WRAPPER len="5" >
<PDU>
<ReleaseResponse>
</ReleaseResponse>
</PDU>
</WRAPPER>
1) 00 01 00 01 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 43 54 54 30 30 30 30 30 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 29 E6 F0 D6 58 5B 41 76 F1 17 CF EE 84 7F 8A 34 BE 23 04 21 21 1F 30 00 02 8F AA 1B 03 BA 06 9B 43 C2 6F A9 2D 73 9D 9C 45 54 CD CA 95 D5 A1 BC 86 2E C6 55 43
2) 00 01 00 01 00 01 00 6B 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 5A 50 41 00 3B 9C 25 32 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 32 89 D6 2E 4E C5 B2 90 6A B4 A5 4D 2E 80 39 AF BE 23 04 21 28 1F 32 00 02 98 A7 E2 FF A4 FA 91 27 8E B1 9C F5 DB E7 5D 2E 9C AB 7B 16 3A 3F DF B6 50 CB 02 34 00
TRANSLATED:
1: 00 01 00 01 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 43 54 54 30 30 30 30 30 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 29 E6 F0 D6 58 5B 41 76 F1 17 CF EE 84 7F 8A 34 BE 23 04 21 21 1F 30 00 02 8F AA 1B 03 BA 06 9B 43 C2 6F A9 2D 73 9D 9C 45 54 CD CA 95 D5 A1 BC 86 2E C6 55 43
<WRAPPER len="E" >
<PDU>
<CallingAPTitle Value="4354543030303030" />
<MechanismName Value="HighGMAC" />
<CallingAuthentication Value="29E6F0D6585B4176F117CFEE847F8A34" />
<!-- Decrypted data:
Invocation Counter: 167850
<InitiateRequest>
</InitiateRequest>
<glo_InitiateRequest Value="3000028FAA1B03BA069B43C26FA92D739D9C4554CDCA95D5A1BC862EC65543" />
</PDU>
</WRAPPER>
2: 00 01 00 01 00 01 00 6B 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 5A 50 41 00 3B 9C 25 32 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 32 89 D6 2E 4E C5 B2 90 6A B4 A5 4D 2E 80 39 AF BE 23 04 21 28 1F 32 00 02 98 A7 E2 FF A4 FA 91 27 8E B1 9C F5 DB E7 5D 2E 9C AB 7B 16 3A 3F DF B6 50 CB 02 34
<WRAPPER len="E" >
<PDU>
<!-- AuthenticationRequired -->
<ACSEServiceUser Value="0E" />
<!-- DLMS system title:
Manufacturer Code: ZPA
Serial number: 10233138
<RespondingAPTitle Value="5A5041003B9C2532" />
<RespondingAuthentication Value="3289D62E4EC5B2906AB4A54D2E8039AF" />
Invocation Counter: 170151
<InitiateResponse>
</InitiateResponse>
<glo_InitiateResponse Value="32000298A7E2FFA4FA91278EB19CF5DBE75D2E9CAB7B163A3FDFB650CB0234" />
</PDU>
</WRAPPER>
So, how to make it work with python? I used same values in both python and GXDLMSDirector.
Also - how can I import certificates/keys in python code? I saw there's something like "self.certificates = []" and "self.publicKeys = []" - should I just put path to key/cert in array? My python code is below (it's just slightly changed GXSettings.py file, running main.py makes it work like passing flags in cmd):
def getParameters(self, args):
parameters = GXSettings.__getParameters(args, "h:p:c:s:r:i:It:a:p:P:g:S:n:C:v:o:T:A:B:D:d:l:W:w:f:L:M:")
self.client.useLogicalNameReferencing = True
self.client.interfaceType = InterfaceType.WRAPPER
self.trace = TraceLevel.VERBOSE
self.client.authentication = Authentication.HIGH_GMAC
self.client.ciphering.security = Security.AUTHENTICATION_ENCRYPTION
self.client.standard = Standard.DLMS
self.media = GXNet(NetworkType.TCP, "IP_is_here", 4058)
self.media.port = int(4058)
self.client.password = "xxx"
self.invocationCounter = "0.0.43.1.1.255"
GXDLMSObject.validateLogicalName(self.invocationCounter)
self.client.ciphering.systemTitle = GXByteBuffer.hexToBytes("4354543030303030")
self.client.ciphering.authenticationKey = GXByteBuffer.hexToBytes("xxx")
self.client.ciphering.blockCipherKey = GXByteBuffer.hexToBytes("xxx")
self.client.clientAddress = int(1)
self.client.serverAddress = int(1)
self.client.manufacturerId = "ZPA"
self.serviceClass = ServiceClass.CONFIRMED
self.priority = Priority.HIGH
self.userId = 0
self.maxPduSize = int(2000)
self.securitySuite = SecuritySuite.SUITE_2
self.encrypt = True
self.encrypted = True
self.client.proposedConformance = Conformance.ACTION | Conformance.SELECTIVE_ACCESS | Conformance.SET | Conformance.GET | Conformance.MULTIPLE_REFERENCES | Conformance.BLOCK_TRANSFER_WITH_ACTION | Conformance.BLOCK_TRANSFER_WITH_SET_OR_WRITE | Conformance.BLOCK_TRANSFER_WITH_GET_OR_READ | Conformance.ATTRIBUTE_0_SUPPORTED_WITH_GET | Conformance.ACCESS
if not self.media:
GXSettings.showHelp()
return 1
return 0
Also, I have access to the following keys/certificates:
-LLS Password/HLS secret
-global encryption key
-authentication key
-key encryption key
-meter signing certificate (DER format HEX)
-private signing key (hex)
-client signing certificate (DER format HEX)
Working settings in GXDLMSDirector are on image: https://ibb.co/nMzGddwR
1 year 8 months ago
Hi, The connection fails…
The connection fails because Python currently does not support security suite 2.
mick93
1 year 8 months ago
Hi, thanks for response!…
thanks for response! Will it work with python someday, too? Does suite2 work with java or C? Thanks!
1 year 8 months ago
Hi, Yes, it's coming to…
Yes, it's coming to Python, but I don't know the release day yet.
ANSI C is supporting Security Suite 2 with GMAC, put the ECDSA is not supported.
Java is supporting Security Suite 2.
