  3. Gurux Dlms Available Functionality From Meter Initiated Connection
gurux dlms available functionality from meter initiated connection
By MichaelMarais , 16 October, 2024
Gooday,
with the gurux dlms, if the connection is initiated by the meter and connected to my tcp connection, am I able to request specific info from the meter via association / send
tokens to the meter or is this only possible via server initiated connections(server initiate connection to meter)?
1 year 11 months ago
Hi, If your meter is…
If your meter is supporting auto connection it can establish the connection to the server.
If the meter doesn't support auto connection, the client must always establish the connection to the meter.
MichaelMarais
Hi Kurumi It does support…
Hi Kurumi
It does support auto connect & is connecting to my server,
do I have to use GXDLMSServer to request info/ send tokens or should I use GXDLMSSecureClient / GXDLMSClient ?
I have tried using the GXDLMSSecureClient & GXDLMSClient but im unable to get past reading the initial data the meter sends(which is just 2 OBIS codes & serial number), I cant establish association view.
1 year 10 months ago
Hi, There are multiple…
There are multiple arguments with DLMS and the meter doesn't reply if one of them is something else than the meter expects.
Try to connect with GXDLMSDirector. The correct settings are defined in the meter manual.
