When I am working with the DLMSDirector, but also my own testcode, I encounter a weird issue.
My meter has load profiles that have no capture objects from factory. Therefore, I am adding this myself via DLMS. Adding, and removing is figured out in both the director and testcode.
However, when I want to remove all capture objects from this originally empty list. I get an error message. The error only occurs when want to remove the last item in the list. When we go from a list with 1 or more capture objects to and complete empty list.
The Error message is: Access Error: Data Block Unavailable
Kind regards,
Robin
Hi Robin, This is the meter…
Hi Robin,
This is the meter issue. The meter doesn't allow you to remove all capture objects.
You can ask if a firmware update is available from the meter manufacturer, but I don't believe this is a big problem, because usually there is at least one capture object.
