  3. Removing Last Capture Object From Load Profile Error
Removing last capture object from load profile error
By Robin Niezen , 30 August, 2024
When I am working with the DLMSDirector, but also my own testcode, I encounter a weird issue.
My meter has load profiles that have no capture objects from factory. Therefore, I am adding this myself via DLMS. Adding, and removing is figured out in both the director and testcode.
However, when I want to remove all capture objects from this originally empty list. I get an error message. The error only occurs when want to remove the last item in the list. When we go from a list with 1 or more capture objects to and complete empty list.
The Error message is: Access Error: Data Block Unavailable
Kind regards,
Robin
2 years 2 months ago
Hi Robin, This is the meter…
Hi Robin,
This is the meter issue. The meter doesn't allow you to remove all capture objects.
You can ask if a firmware update is available from the meter manufacturer, but I don't believe this is a big problem, because usually there is at least one capture object.
