  3. In Which Format We Can Give Start and End Date and Time In Reading Block Load Profile
In which format we can give start and end date and time in reading block load profile
By satishjyoti1998 , 17 July, 2024
In which format we can give start and end date and time in reading block load profile. Please help.
Regards
Satish
2 years 4 months ago
Hi, You didn't tell what…
You didn't tell what programming language you are using, but check the client example. Some meters expect minutes, seconds, and milliseconds to be set to zero or meter returns an error.
satishjyoti1998
2 years 3 months ago
Hi Mikko. I'm using Python…
Hi Mikko.
I'm using Python language.
Regards
Satish
Hi, You can set start and…
You can set start and end times like this:
https://github.com/Gurux/Gurux.DLMS.Python/blob/9c7e211eb9dce49366c16de…
