  3. Convert It To Readable String
Convert it to readable string
By mafrmota , 2 May, 2024
It's possible in DLMSDirector convert octet value to readable string?
Marco
2 years 6 months ago
Hi, Yes, it is. It's done…
Yes, it is. It's done automatically if the OBIS code is defined on the standard, but if it is not, you can select "Access Rights" tab and change UIType to string. Value is shown as a string after you read it.
