  3. Distinguish Between 3 Phase and Single Phase Meters
Distinguish between 3 phase and single phase meters
By kevin jose minj , 18 May, 2023
Is there any way to distinguish between 3 phase and single phase meters after establishing connectivity through python gurux library?
3 years 6 months ago
Hi, You can try to read the…
You can try to read the meter model and check if the meter model is 1 or 3 phase meter from you local DB.
