By kevin jose minj , 18 May, 2023 Forums General discussion Is there any way to distinguish between 3 phase and single phase meters after establishing connectivity through python gurux library? Hi, You can try to read the… Hi, You can try to read the meter model and check if the meter model is 1 or 3 phase meter from you local DB. BR, Mikko
