  3. Unhandled Exception. MySql.Data.MySqlClient.MySqlException (0x80004005): Incorrect Datetime Value
Unhandled exception. MySql.Data.MySqlClient.MySqlException (0x80004005): Incorrect datetime value
Profile picture for user riahtu
By riahtu , 7 January, 2023
Gurux.DLMS.AMI
I download Gurux.DLMS.AMI4 from github, when I compile then run Gurux.DLMS.AMI4, it reports the below problem. Do you have any idea? Please kindly help me.
Unhandled exception. MySql.Data.MySqlClient.MySqlException (0x80004005): Incorrect datetime value: '2023-01-06 23:43:16+00:00' for column `dlms_db`.`GXConfiguration`.`Updated` at row 1
3 years 9 months ago
We can't repeat this.
If you are using Linux what distro you are using and what is the outcome if you run locale in the command prompt?
locale
Let me know those, and the same environment is set to solve this.
  • hezhangnihao@163.com
  • ZilvinasN
  • Yosr
  • albino.ramon
  • JosepM
