  3. Gurux.DLMS.AMI4
Gurux.DLMS.AMI4
By Administrator , 10 November, 2022
View releasesView issues
Join the Gurux Community or follow @Gurux for project updates.
Gurux.DLMS.AMI is a part of Gurux Device Framework. For more info check out Gurux.
General information
Purpose of Gurux.DLMS.AMI component is given FAST and SIMPLE Advanced Metering Infrastructure for DLMS meters. This project consists of three different part Gurux.AMI offers a meter reading application that you can schedule or order to read wanted objects from DLMS meters. Read values are saved to the database.
Starting with Gurux.AMI
Gurux.AMI is using .Net Core 8. First, you must install it on your PC or use Gurux Docker. You can download docker file from here. You can get source codes from GitHub
Database
At the moment Gurux.AMI is supporting the following databases:
  • MySql
  • Maria BD
  • Microsoft SQL Server
  • Oracle
Examples for database settings
Quick start examples are available here. Docker database settings are defined here.
  • MariaDB and MySQL
    Server=HOST;Database=DATABASE;UID=USER_ID;Password=PASSWORD
  • Microsoft SQL Server (MSSQL)
    Server=HOST;Database=DATABASE;User Id=USER_ID;Password=PASSWORD;
  • Oracle
    User Id=USER_ID;Password=PASSWORD;Data Source=HOST_NAME:1521/XEPDB1;
Update USER_ID, PASSWORD, and HOST_NAME to what you use in your database. Note! Connection strings might vary for the used database version. You can start the Gurux.DLMS.AMI as defined here or with dotnet. Go Server directory (Gurux.DLMS.AMI4/Gurux.DLMS.AMI/Gurux.DLMS.AMI/Server) and run Gurux.DLMS.AMI.Server like this:
dotnet run --environment Development
Now you can test that Gurux.DLMS.AMI is up and running starting browser:
https://localhost:8001/
Creating user
At first you need to create an administrator user. This is done by selecting "Register". Fill your email address and password to create user. The first user is admin user. Default user roles can be set in "Configuration/Roles".
Creating Device template
The Device template will define meter settings. Each meter is different and the settings are also different. You can connect for the meter with GXDLMSDirector and remove unnecessary device objects. Then you can import the device settings file by selecting "Device Templates" and pressing the Add button. This might take some time if the device template is large. The new device template is imported when the Save button is pressed.
Creating Device
After the device template is imported a new device can be created by selecting "Devices" and pressing "Add" button. Set name for the device and set the correct parameters. After that, the new device is created.
Agent access token
Because all communication is encrypted you need to generate a token for the agent. It's done by selecting "Generate access token". Save this token, because it's not saved anywhere. It's needed when a new agent is added.
Agent
The agent will collect data from the meter. The agent will establish the connection for the Gurux.DLMS.AMI server and will wait for new tasks to execute. The agent is downloaded to PC by selecting "Agents" and pressing "Add" button. Then select "Download the agent"- Unzip agent for the folder and start it by running
dotnet Gurux.DLMS.AMI.Agent.dll
Agent will ask for the communication parameters when it's started for the first time. Set the corrected parameters and you can see the agent is connected by selecting "Agents". Agent status should be Connected to indicate the agent is ready to execute the tasks.
Reading the value from the meter.
After the agent is operating and the meter is added you can see meter objects by selecting the wanted device. Selecting the object and pressing the read -button the new task is added to the task list and the agent will start to read it. The value is updated for the user interface as soon as it's read.
Key management System
Key Management System is build in for Gurux.DLMS.AMI. Device secrets are shown for the user only when a new device is created. After that secret information can be accessed only using key management system.
Using Gurux.DLMS.AMI from other applications.
Gurux.DLMS.AMI is offering REST interface that can be used to read or write values. All the commands are available by selecting https://localhost:8001/swagger/ Before use REST interface you need to create a Personal Access Token.
You need a personal access token to access the Gurux.DLMS.AMI services from other applications. The personal access token is done by selecting the profile from the upper right corner or https://localhost:8001/Identity/Account/Manage
Then select "Personal Access Token" and press "Add" button. Give a name for the token and select scopes that you want to access.
  • Agent
  • Configuration
  • Device
  • Device template
  • Extensions
  • Favorites
  • Gateway
  • REST statistic
  • Report
  • Schedule
  • Subtotal
  • System log
  • Tasks
  • User
Book traversal links for Gurux.DLMS.AMI4
  • Agent ›
Book navigation
  • Agent
  • Configuration
  • Device
  • Device template
  • Extensions
  • Favorites
  • Gateway
  • REST statistic
  • Report
  • Schedule
  • Subtotal
  • System log
  • Tasks
  • User
