  3. DLMS Translator
DLMS Translator
By mrazoun , 17 December, 2021
I'm using DLMS Translator, running from GXDLMSDirector -> Tools.
The application is very helpfull for me, but now is not possible to use it. It's falling down.
I used it in the past without problem. Mayby installation of new version ?
My version is 8.2.2112.1601
It's going through two error messages, application completely fall down at the end.
The first message comes, when I start DLMS Translator from menu.
The second message comes, when I choose "Translate" from menu DLMS Translator.
There is my translation of error messages:
Message 1 "Pointer to object is not set on object instance".
Message 2 "Unresolved exception......"
Thank you in advance,
Zdenek
Sample of data :
7E A0 19 03 21 1A 25 75 E6 E6 00 C0 01 C1 00 03 07 00 0B 1A 00 FF 02 00 45 FE 7E
7E A0 19 21 03 D0 73 BA E6 E7 00 C4 01 C1 00 18 40 91 5C 00 00 00 00 00 67 F2 7E
Details of exeptions :
System.NullReferenceException: Odkaz na objekt není nastaven na instanci objektu.
v GXDLMSDirector.DLMSTranslatorForm.UpdateSecuritySettings()
v GXDLMSDirector.DLMSTranslatorForm.TranslateBtn_Click(Object sender, EventArgs e)
v System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
v System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
v System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
v System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
v System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
v System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
v System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
v System.Windows.Forms.Control.WndProc(Message& m)
v System.Windows.Forms.ToolStrip.WndProc(Message& m)
v System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
v System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Načtená sestavení **************
mscorlib
Verze sestavení: 4.0.0.0
Verze Win32: 4.7.2600.0 built by: NET471REL1LAST
Základ kódu (CodeBase): file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
System
Verze Win32: 4.7.2556.0 built by: NET471REL1
Základ kódu (CodeBase): file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
GXDLMSDirector
Verze sestavení: 8.2.2112.1601
Verze Win32: 8.2.2112.1601
4 years 10 months ago
I can't repeat your error but select Ciphering settings. Then check that Security Suite and security are selected. I believe one of your dropdown lists is not empty and it's causing this problem.
mrazoun
thank you for quick response.
Sorry I don't undestood what shall I do. Pls. give me more details.
Look into attachment, there is my print screen.
Best regards,
Zdenek
Ciphering tab is missing. Can you select "Help" and "Library Versions". Can you add your version information here? I'll check this on Monday.
mrazoun
there are requested information :
.NET Framework 3.5SP1 3.5.30729.4926 C:\Windows\Microsoft.NET\Framework64\v3.5\
.NET Framework 4.0 4.7.02556 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\
GXDLMSDirector 8.2.2112.1601 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\GXDLMSDirector.exe
Gurux.Common 8.1.2109.2401 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\Gurux.Common.dll
Gurux.MQTT 8.1.2109.2401 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\Gurux.MQTT.dll
Gurux.DLMS.AMI.UI 8.1.2112.902 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\Gurux.DLMS.AMI.UI.dll
Gurux.DLMS 9.0.2112.905 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\Gurux.DLMS.dll
Gurux.DLMS.UI 9.0.2112.1601 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\Gurux.DLMS.UI.dll
Gurux.Net 8.1.2109.2401 C:\Users\*userFolder*\AppData\Local\Apps\2.0\C0JOE8VV.017\O4P36OXD.YY0\gxdl..tion_214ea302fa5c7dd5_0008.0002_9bedaf6e7e185ae2\Gurux.Net.dll
Zdenek
Are you getting the error when you open Translator? The only reason for this is if you can't create Certificates or Keys folder under MyDocuments\GXDLMSDirector. Can you check if those folders exists?
You should see those orders if you Select "File" and "Open" in GXDLMSDirector. If you can't see them, try to create them by yourself.
mrazoun
unfortunately no success.
- folders Cerificates and Keys was already exist. I deleted them. I started Translator, both folders were created automatically, but empty.
- uninstal (of GXDLMSDirector) & install procedure also without success.
- The first error message I got when I start Translator. Message 1 "Pointer to object is not set on object instance".
Thank you and best regards.
Zdenek
The reason is solved. The new version is released and you should see it when you restart GXDLMSDirector. Thank you for pointing this out. It was a little bit hard to find, but it was easy to fix.
mrazoun
thank you a lot for a good message.
I started GXDLMSDirector, no update happens.
I also tried "Help -> Check for updates". I got message "No updates available."
When will be update available ?
My current version is 8.2.2112.1601
Zdenek
There is version 8.2.2112.2101. You should be notified of the new version when you restart the GXDLMSDirector. If nothing else doesn't help remove it and re-install it here:
http://gurux.fi/Download
mrazoun
problem is solved.
Many thank's for your help and I wish you happy New Year.
Zdenek
  • APFC TEAM1
