  3. Arduino IDE Read TokenGateway Data
Arduino IDE read TokenGateway data
By Bill , 23 September, 2021
I use Gurux to get token gateway code and it works.
Now I`m trying to use Arduino IDE to get token data,but I got something error.
Here is my Arduino code:
gxTokenGateway objToken;
unsigned char token[20] = {0x31, 0x37, 0x36, 0x32, 0x32, 0x34, 0x34, 0x39, 0x37, 0x30, 0x36, 0x31, 0x31, 0x35, 0x30, 0x34, 0x39, 0x32, 0x35, 0x30};
gxByteBuffer bb;
BYTE_BUFFER_INIT(&bb);
if ((ret = bb_setUInt8(&bb, DLMS_DATA_TYPE_OCTET_STRING)) == 0 &&
(ret = hlp_setObjectCount(sizeof(token), &bb)) == 0 &&
(ret = bb_set(&bb, token, sizeof(token))) == 0)
dlmsVARIANT params;
var_init(&params);
var_setInt8(&params, 0);
var_addOctetString(&params, &bb);
var_addBytes(&params, token, sizeof(token));
cosem_init(BASE(objToken), DLMS_OBJECT_TYPE_TOKEN_GATEWAY, "0.0.19.40.0.255");
com_method(BASE(objToken), 1, &params);
data = bb_toHexString(&objToken.token);
obj_toString(BASE(objToken), &data);
GXTRACE(PSTR("Ori token : "), data);
obj_clear(BASE(objToken));
free(data);
Response:
:com_method section2 failed. 12
:Ori token : Index: 2 Value:
What`s wrong with my code?
My Arduino IC specification is Mega2560
Bill
5 years 1 month ago
Try to remove this line:
Bill
5 years 1 month ago
Hi Mikko:
Hi Mikko:
It still not work.
Bill
5 years 1 month ago
Your code looks correct. Can you get a trace from the bytes send so I can check what might be the problem?
Bill
5 years 1 month ago
Hi Mikko:
Hi Mikko:
I sent an email to you.
Please help me to check my collected data.
Bill
5 years 1 month ago
I was not receiving it. Can you share it on textbin.net?
Ferdinand
4 years 12 months ago
I also have the same problem with Bill.
Can you help me with this problem ?
Ferdinand
Hi Ferdinand,
Hi Ferdinand,
Can you create a new topic and share sent bytes, so I can check what is the problem.
  • APFC TEAM1
