  3. Server Responding With Receive Ready Frame.
Server responding with receive ready frame.
By arolo , 28 July, 2021
Hello there!
First of all, Sorry if the question is too obvious I am new to this DLMS protocol.
I am trying to read energy measure from a meter, I am able to open and close session correctly, as well as read the clock.
First the profile is read which apparently is done successfully, however when the measurement request is made, first the server does not respond at all, so the client tries to make the request again and that when the server responds with a RECEIVE READY frame. I understood that this frame was sent to the client from the server, what can it mean when is the server the one sending it to the client?
The frame exchange is as follows.
-> 7E A0 47 00 02 58 9F 21 D4 C5 B1 E6 E6 00 05 01 04 43 88 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 07 0D 02 00 00 00 FF 80 00 80 09 0C 07 E5 07 0E 03 00 00 00 FF 80 00 80 01 00 4C 59 7E
<- (no frame received)
<- 7E A0 0A 21 00 02 58 9F 71 B1 12 7E
I am stuck here any help will be greatly appreciated
5 years 3 months ago
Can you read the data if you read all the data without start and end time? Some meters expect that the date-time format is in a specific format and handle others. What is your meter model and manufacturer?
arolo
Thanks very much for your response!
The manufacturer is LANDIS & GYR and the model LGZ_2_ZMQ202C.8r4af6_H03
I am triying to connect to the device using DLMS Gurux director using the properties show in the image, I think the configuration its ok since it is able to connect with the device, however when i try to read object I get the following error:
GXDLMSDirector 8.2.2107.2101
Log created 13:39:05
13:39:06 Initializing Network connection.
13:39:06 01:39:06.422 Info Opening
13:39:06 01:39:06.423 Info Configuración del cliente: Protocolo Tcp Anfitrión: localhost Puerto: 4001
13:39:06 01:39:06.424 Info Open
13:39:06 Send SNRM request.
7E A0 0A 00 02 58 9F 21 93 37 6E 7E
13:39:06 01:39:06.936 Sent 7E A0 0A 00 02 58 9F 21 93 37 6E 7E
13:39:07 01:39:07.278 Received 7E A0 21 21 00 02 58 9F 73 A2 24 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
13:39:07
13:39:07 Parsing UA reply succeeded.
13:39:07 Send AARQ request.
7E A0 2E 00 02 58 9F 21 10 51 D4 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
13:39:07 01:39:07.279 Sent 7E A0 2E 00 02 58 9F 21 10 51 D4 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
13:39:07 01:39:07.709 Received 7E A0 3A 21 00 02 58 9F 30 76 97 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 0A A8 7E
13:39:07
13:39:07 Parsing AARE reply succeeded.
13:39:09 --- Collecting objects. ---
13:39:09 Collecting objects
7E A0 14 00 02 58 9F 21 32 5C E9 E6 E6 00 05 01 02 FA 08 18 9E 7E
13:39:09 01:39:09.538 Sent 7E A0 14 00 02 58 9F 21 32 5C E9 E6 E6 00 05 01 02 FA 08 18 9E 7E
13:39:10 01:39:10.023 Received 7E A8 5E 21 00 02 58 9F 52 2D 31 E6 E7 00 0C 01 00 01 82 01 4A 02 04 10 2B C0 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 04 10 00 10 12 27 13 11 18 09 06 00 00 F0 0D 00 FF 02 04 10 00 F0 12 27 18 11 01 09 06 00 00 F0 00 00 FF 02 04 10 01 58 12 00 03 11 00 09 06 01 01 01 08 01 FF 3F 53 7E
13:39:10
13:39:10 Get next frame.
13:39:10 Collecting objects
7E A0 0A 00 02 58 9F 21 51 29 8B 7E
13:39:10 01:39:10.023 Sent 7E A0 0A 00 02 58 9F 21 51 29 8B 7E
13:39:10 01:39:10.412 Received 7E A8 54 21 00 02 58 9F 54 4C BD 02 04 10 02 08 12 00 03 11 00 09 06 01 01 01 08 02 FF 02 04 10 02 B8 12 00 03 11 00 09 06 01 01 01 08 03 FF 02 04 10 03 68 12 00 03 11 00 09 06 01 01 02 08 01 FF 02 04 10 04 18 12 00 03 11 00 09 06 01 01 02 08 02 FF D1 00 7E
13:39:10
7E A0 0A 00 02 58 9F 21 71 2B AA 7E
13:39:10 01:39:10.413 Sent 7E A0 0A 00 02 58 9F 21 71 2B AA 7E
13:39:10 01:39:10.808 Received 7E A8 54 21 00 02 58 9F 56 5E 9E 02 04 10 04 C8 12 00 03 11 00 09 06 01 01 02 08 03 FF 02 04 10 05 78 12 00 03 11 00 09 06 01 01 05 08 01 FF 02 04 10 06 28 12 00 03 11 00 09 06 01 01 05 08 02 FF 02 04 10 06 D8 12 00 03 11 00 09 06 01 01 05 08 03 FF 30 0B 7E
13:39:10
7E A0 0A 00 02 58 9F 21 91 25 4D 7E
13:39:10 01:39:10.809 Sent 7E A0 0A 00 02 58 9F 21 91 25 4D 7E
13:39:11 01:39:11.203 Received 7E A8 54 21 00 02 58 9F 58 20 77 02 04 10 07 88 12 00 03 11 00 09 06 01 01 06 08 01 FF 02 04 10 08 38 12 00 03 11 00 09 06 01 01 06 08 02 FF 02 04 10 08 E8 12 00 03 11 00 09 06 01 01 06 08 03 FF 02 04 10 09 98 12 00 03 11 00 09 06 01 01 07 08 01 FF 33 8A 7E
13:39:11
13:39:11 Get next frame.
13:39:11 Collecting objects
7E A0 0A 00 02 58 9F 21 B1 27 6C 7E
13:39:11 01:39:11.204 Sent 7E A0 0A 00 02 58 9F 21 B1 27 6C 7E
13:39:11 01:39:11.592 Received 7E A8 54 21 00 02 58 9F 5A 32 54 02 04 10 0A 48 12 00 03 11 00 09 06 01 01 07 08 02 FF 02 04 10 0A F8 12 00 03 11 00 09 06 01 01 07 08 03 FF 02 04 10 0B A8 12 00 03 11 00 09 06 01 01 08 08 01 FF 02 04 10 0C 58 12 00 03 11 00 09 06 01 01 08 08 02 FF 77 BA 7E
13:39:11
7E A0 0A 00 02 58 9F 21 D1 21 0F 7E
13:39:11 01:39:11.592 Sent 7E A0 0A 00 02 58 9F 21 D1 21 0F 7E
13:39:11 01:39:11.985 Received 7E A8 54 21 00 02 58 9F 5C 04 31 02 04 10 0D 08 12 00 03 11 00 09 06 01 01 08 08 03 FF 02 04 10 0D B8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 0E 68 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 0F 18 12 00 03 11 00 09 06 00 00 7F 00 00 00 80 2A 7E
13:39:11
7E A0 0A 00 02 58 9F 21 F1 23 2E 7E
13:39:11 01:39:11.986 Sent 7E A0 0A 00 02 58 9F 21 F1 23 2E 7E
13:39:12 01:39:12.373 Received 7E A8 54 21 00 02 58 9F 5E 16 12 02 04 10 0F C8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 10 78 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 11 28 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 11 D8 12 00 03 11 00 09 06 00 00 7F 00 00 00 EB 99 7E
13:39:12
13:39:12 Get next frame.
13:39:12 Collecting objects
7E A0 0A 00 02 58 9F 21 11 2D C9 7E
13:39:12 01:39:12.373 Sent 7E A0 0A 00 02 58 9F 21 11 2D C9 7E
13:39:12 01:39:12.768 Received 7E A8 54 21 00 02 58 9F 50 68 FB 02 04 10 12 88 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 13 38 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 13 E8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 14 98 12 00 03 11 00 09 06 00 00 7F 00 00 00 DD 66 7E
13:39:12
7E A0 0A 00 02 58 9F 21 31 2F E8 7E
13:39:12 01:39:12.768 Sent 7E A0 0A 00 02 58 9F 21 31 2F E8 7E
13:39:13 --- Collecting objects. ---
13:39:13 Collecting objects
7E A0 14 00 02 58 9F 21 54 6C EF E6 E6 00 05 01 02 FA 08 18 9E 7E
13:39:13 01:39:13.157 Received 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E
13:39:23 Data send failed. Try to resend 1/3
13:39:23 01:39:23.158 Sent 7E A0 0A 00 02 58 9F 21 31 2F E8 7E
13:39:23 01:39:23.553 Received 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E
13:39:33 Data send failed. Try to resend 2/3
13:39:33 01:39:33.556 Sent 7E A0 0A 00 02 58 9F 21 31 2F E8 7E
13:39:33 01:39:33.948 Received 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E
13:39:43 Data send failed. Try to resend 3/3
13:39:43 01:39:43.953 Sent 7E A0 0A 00 02 58 9F 21 31 2F E8 7E
13:39:44 01:39:44.342 Received 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E
13:39:54 Failed to receive reply from the device in given time.
7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E 7E A8 54 21 00 02 58 9F 52 7A D8 02 04 10 15 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 15 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 16 A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 17 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 01 BF 7E
13:39:54
13:39:54 01:39:54.347 Sent 7E A0 14 00 02 58 9F 21 54 6C EF E6 E6 00 05 01 02 FA 08 18 9E 7E
System.Exception: GetObjects failed. Failed to receive reply from the device in given time.
en GXDLMSDirector.MainForm.RefreshDevice(GXDLMSMeter dev, Boolean bRefresh)
en GXDLMSDirector.MainForm.Refresh(Object sender, GXAsyncWork work, Object[] parameters)
13:40:04 Failed to receive reply from the device in given time.
en GXDLMSDirector.MainForm.ReadDevice(GXDLMSMeter d)
en GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
13:40:39 Disconnect request
7E A0 0A 00 02 58 9F 21 53 3B A8 7E
13:40:39 01:40:39.848 Sent 7E A0 0A 00 02 58 9F 21 53 3B A8 7E
13:40:40 01:40:40.190 Received 7E A0 21 21 00 02 58 9F 73 A2 24 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
13:40:40
13:40:40 01:40:40.190 Info Closing
13:40:40 01:40:40.191 Info Closed
Have you pressed refresh twice? Reading will take a long time. Wait until the association read is done.
arolo
You were right, I was been impatient when I wait and refresh the device I was able to read some of the objects, but now I get a new problem, I am getting "not enough memory error" I read , this could be because the meter tells that maximum PDU size is different from the message it is actually sendind, or maybe I dont have enough memory on my heap.
It is able to read some objects so I try to read only one of then I get the same error of memory. How do I difference the source of this error?
Arolo
If you are using GXDLMSDirector, then the data is strange. Can you send the hex trace by email so I can check what is the problem?
You can find my email address from here:
https://www.gurux.fi/AboutUs
arolo
I sent you the trace by email, if you need anything else let me know.
thanks!.
I checked the data. The meter sends Receive Ready when you read the profile generic and actual data is coming about 6 seconds later,
Is this happening every time? Is this happening when you are reading all the data without start and end time?
It might be that the meter needs more time to find data and send RR to indicate this, but this is a custom way to do it.
arolo
5 years 2 months ago
Hi there!
Hi there!
I have managed to get the measurement correctly after all, I was asking for another OBIS code that was not correct. Now everything works perfectly for me.
Thank you very much for all your help, I am sorry for the delay in responding, I was a few days away.
Arolo
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
