  3. Issue Connection With Gprs Modem
issue connection with gprs modem
By tagmout , 21 September, 2020
Hi mikko ,
We want to communicate with a CLOU meter via gprs modem ( @ip) , but it gives the error message :" no connection could be established because the target computer expressly refused it" , we tried with both IEC and DLMS .
we use the device properties below :
6 years 1 month ago
Are you using a static IP address? If you are using a dynamic IP address you can't establish the connection to the meter. You can read more:
tagmout
6 years 1 month ago
Yes , I'm using a static IP
Yes , I'm using a static IP address with a VPN nerwork .
6 years 1 month ago
Then you have a firewall or something else that is blocking the connection. This is TCP/IP error and it's coming from the operating system.
tagmout
6 years 1 month ago
Hi Mikko ,
Hi Mikko ,
I don't think so because I can ping IP of meter from my computer . Perhaps something else ,
6 years 1 month ago
Firewall might block this connection because ping is using a different port.
Also, make sure that it's your meter that is replying. Close the meter and try to ping again.
You should not receive pings now.
tagmout
6 years 1 month ago
I can't ping when i close the
I can't ping when i close the meter .
6 years 1 month ago
Then there is a firewall or
Then there is a firewall or your port number is wrong.
tagmout
6 years 1 month ago
still the same error message
still the same error message " No connection could be made because the target computer actively refused I checked the firewall it's OK and I used 4059 as a number port . perhaps another thing that block this connection .
6 years 1 month ago
If you can read your meter using the optical or serial port you can check the port from TcpUdp Setup object.
