  3. Ningbo Sanxing Smart Electric
By tagmout , 9 September, 2020
Hi Mikko ,
we can read NINGO SANXING SMART METER with GXDLMSDirector ?
6 years 1 month ago
Our clients are reading Sanxing SX meters. If your meters are supporting DLMS there should be no reason why you can't.
tagmout
6 years 1 month ago
there is no sanxing in the
there is no sanxing in the manufacturer option , which one i have to use ?
and i use IEC or DLMS in start protocol ?
Thanks a lot .
tagmout
6 years 1 month ago
We use this one below with
We use this one below with the optical cable .
http://www.sanxingelectric.com/prodeta.php?id=5bmy5ra4ezEzMH10aGlzX2lzX…
6 years 1 month ago
You can use example with Gurux. Try without authentication first.
Our clients are reading them using TCP/IP connection so I can't say for sure but
if the meter doesn't reply change the Start protocol from DLMS to IEC.
tagmout
6 years 1 month ago
i try with these parameters
i try with these parameters in the attached picture , but no work
below , the logs :
12:00:08 Initializing serial connection.
12:00:09 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
12:00:14 Data send failed. Try to resend 1/3
12:00:19 Data send failed. Try to resend 2/3
12:00:24 Failed to receive reply from the device in given time.
12:00:24 Disconnect request
12:00:24 Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
12:00:29 Data send failed. Try to resend 1/3
12:00:34 Data send failed. Try to resend 2/3
12:00:39 Failed to receive reply from the device in given time.
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
6 years 1 month ago
Select Advanced and try to change the baud rate. The easiest is if you ask correct settings from the meter manufacturer.
tagmout
6 years 1 month ago
Can You please check with us
Can You please check with us if this meter supports DLMS ,
Thank You a lot of ,
6 years 1 month ago
That link doesn't tell anything. There is only basic info. You need to ask this from the meter vendor.
tagmout
6 years 1 month ago
Dlms logo is printed on the
Dlms logo is printed on the meter so it supports dlms of course
6 years 1 month ago
If there is a logo, then you can read it using Gurux products. Our clients are reading Sanxing meters using TCP/IP connection. If you want to use Low authentication client address is 32 (0x20).
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
