  3. Interpretation of Bit-String Values I.e From Where Bit 0 Shall Start
Interpretation of Bit-String Values i.e from where Bit 0 Shall Start
By deepaks , 22 May, 2020
Please tell me Is it the correct interpretation of Value field(for Bit-String Data Type) in following example:
04 10 26 4A
Bit 0 - 0
Bit 1 - 1
Bit 2 - 0
Bit 3 - 1
Bit 4 - 0
Bit 5 - 0
Bit 6 - 1
Bit 7 - 0
Bit 8 - 0
Bit 9 - 1
Bit 10 - 1
Bit 11 - 0
Bit 12 - 0
Bit 13 - 1
Bit 14 - 0
Bit 15 - 0
Thanks in Advance
6 years 5 months ago
04 10 26 4A = 0010011001001010
In bit-string first bit is on the left side, not at the end. In this way new bits are happened to the end of bit string.
If you download GXDLMSDirector and select "Tools", and "DLMS Translator" and then select "Data to XML tab" you can validate bit string by your self adding your bytes and pressing "PDU To XML" button.
deepaks
Thanks for your Prompt Reply !!!
where is the Bit 0 located extreme left or extreme right
<BitString Value="00000000000000000000000000000000000000001001000000000000000000000000000000000000000000000000000000000000000000000000000000010000" />
Thanks in Advance
Hi Deepak ,
Hi Deepak ,
The first bit is located on the left. This is because there might be new bits in the future and if they are added to the left, it will break backward compatibility. This is common example in Image Transfer. Image size might grow and new blocks are needed to send the image.
deepaks
In reply to Hi Deepak , by Kurumi
Thanks a lot, now i got the concept behind the Bit-Strings.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
