  3. How To Handle Push Message In Ansi C Library
how to handle push message in ansi c library
By Mohanraj , 21 April, 2020
could you please provide sample code for handling push message in ansi c library being client?
push messages are 1.instantaneous data 2. Events.
Mohan Raj
6 years 6 months ago
Hi Mohan,
Hi Mohan,
Check push example. It'll do what you want.
https://github.com/Gurux/GuruxDLMS.c/tree/master/GuruxDLMSPushExample
Mohanraj
In reply to Hi Mohan, by Kurumi
ok. I shall check
ok. I shall check
Mohanraj
6 years 5 months ago
In reply to ok. I shall check by Mohanraj
how to i decrypt or interpret the data received from meter? please guide me to sample code.As i told earlier client is connected already. am not having the clear idea about to how to do.
Type1 message:
00 01 00 01 00 40 00 DF DB 08 56 54 4B 30 30 30 30 32 82 00 00 20 00 00 00 01 0F 00 00 00 01 0C 07 E3 0C 0B 03 0D 1F 12 FF 80 00 FF 02 1A 0A 0D 56 54 4B 30 30 39 31 30 30 30 30 30 32 09 06 00 00 19 09 00 FF 09 0C 07 E3 0C 0B 03 0D 1F 12 FF 80 00 FF 12 5C F0 05 00 00 00 00 05 00 00 00 00 10 03 E8 12 13 86 06 00 00 00 00 05 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 09 0C 00 00 00 00 00 00 00 00 FF 80 00 FF 15 00 00 00 00 00 00 00 00 09 0C 00 00 00 00 00 00 00 00 FF 80 00 FF 06 00 00 00 0E 06 00 00 00 00 06 00 00 00 00 06 00 00 00 01 06 00 00 00 00 06 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 03 01 06 00 00 00 11
Type2 message:
00 01 00 01 00 40 00 5F DB 08 56 54 4B 30 30 30 30 31 82 00 00 20 00 00 00 01 0F 00 00 00 01 0C 07 E3 0C 0B 03 0D 10 06 FF 80 00 FF 02 04 0A 0D 56 54 4B 30 30 39 31 30 30 30 30 30 31 09 06 00 04 19 09 00 FF 09 0C 07 E3 0C 0B 03 0D 10 06 FF 80 00 FF 04 82 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00
Below link is for push example i.e it will connect to server and sends push message. But my requirement is different that is being a client how to interpret/decrypt/process the data.
Mohan Raj
Mohanraj
In reply to Hi Mikko, by Mohanraj
Any update please? could you please help me?
Mohan Raj
Hi Mohan,
Hi Mohan,
Please, don't ask for updates. I'll answer as soon as I have time.
When you set keys data is encrypted automatically. There is an issue with data that meter sends.
The size of the ciphered service is invalid (zero). Ask your meter manufacturer to fix it.
Mohanraj
Thanks for the update.
Below is the another message from the meter. could you please tell me how to interpret using ANSI C library?
00 01 00 01 00 20 00 12 C4 01 81 00 09 0C 07 E4 04 0F 03 10 1E 34 FF 80 00 FF 00 01 00 01 00 40 00 DF DB 08 56 54 4B 30 30 30 32 31 82 00 00 20 00 00 00 01 0F 00 00 00 01 0C 07 E4 04 0F 03 10 1E 37 FF 80 00 FF 02 1A 0A 0D 56 54 4B 30 30 39 31 30 30 30 30 32 31 09 06 00 00 19 09 00 FF 09 0C 07 E4 04 0F 03 10 1E 37 FF 80 00 FF 12 5A 12 05 00 00 00 00 05 00 00 00 00 10 03 E8 12 14 0B 06 00 00 00 00 05 00 00 00 00 15 00 00 00 00 00 00 47 4A 15 00 00 00 00 00 00 47 5A 15 00 00 00 00 00 00 00 00 09 0C 00 00 00 00 00 00 00 00 FF 80 00 FF 15 00 00 00 00 00 00 00 00 09 0C 00 00 00 00 00 00 00 00 FF 80 00 FF 06 00 00 5E D9 06 00 00 00 00 06 00 00 00 03 06 00 00 00 01 06 00 00 00 24 06 00 00 00 24 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 03 01 06 00 00 00 11
Please guide me after receiving the above data what are all functions and settings to be done to have data.
Mohan Raj
Mohanraj
I will ask meter manufacturer to fix this and share you proper ciphered push message. So that you can tell me what are things i have to follow to interpret and get the data.
Mohan Raj
Hi Mohan,
Hi Mohan,
Before this is fixed to the meter you can't get the decrypted data.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
