  3. Reading Cumulative TOD Values
By Vageesh , 26 September, 2019
HI,
I am trying to read L&T ER300P meter using Java DLMS statck. I have following queries. Please help me out.
1. Meter is showing all Cumulative kwh, kvah TODwise. But I couldn't read it as instantaneous parameter, using this OBIS code 1.0.1.8.1.255 I get this error "Access Error : Device reports a undefined object".
Please help me to read cumulative TODwise energies.
7 years 1 month ago
You need to change the authentication level to higher. Try to read your meter with GXDLMSDirector first. I believe it helps you to get started.
Vageesh
7 years 1 month ago
We don't have password for High authentication level. If you know any please share. We are using "lnt1" as password for low authentication.
7 years 1 month ago
You need to ask this from the meter vendor.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
