  3. How To Read All Instantaneous Profile Value (Voltage, Current, Etc ) Using Single OBIS Code?
How to read all instantaneous profile value (Voltage, current, etc ) using single OBIS code?
By pradson , 24 July, 2019
Is it possible to read all instantaneous profile value using single OBIS code?
I mean can I read all (current, voltage, power, etc...) using single OBIS code.
Kindly suggest me.
Thanks & Regards,
Pradson
7 years 3 months ago
This is not possible. You can read several objects in one request. All meters don't support it.
Use ReadList-method for that.
pradson
Kindly refer the below mentioned code. After My sample application is not true for first condition and true for second condition. Is it means my meter does not support "readList" method?
Kindly find the attached file of my program and its output. The method "readList" has failed and showing "Invalid Parameters" error.
Kindly suggest me asap.
//First Condition
if ((cl.GetNegotiatedConformance() & DLMS_CONFORMANCE_MULTIPLE_REFERENCES) != 0)
// It means readlist is supported ?
//Second Condition
if ((cl.GetNegotiatedConformance() & DLMS_CONFORMANCE_MULTIPLE_REFERENCES) == 0)
// It means readlist is not supported ?
Pradson
You are right on this. If DLMS_CONFORMANCE_MULTIPLE_REFERENCES bit is not set meter don't support readlist and all the values must read one by one.
znasim
7 years 2 months ago
Hi Mikko
Hi Mikko
I want to connect to meter and read values like voltage and current how should i start?
please help me
In reply to Hi Mikko by znasim
Hi znasim,
Hi znasim,
Please, start a new topic if you have a new question. I'll answer your question there.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
