  3. GuruxDLMSServerExample. Error Occurred While Reading The Association Logical Name
GuruxDLMSServerExample. Error occurred while reading the Association Logical Name
By dlsh , 19 June, 2017
Hello
Let's start the example of GuruxDLMSServerExample.
When you read the Association Logical Name, the error
*Access Error: Device reports a hardware fault.*
appears through the GXSDLMSDirector. [Image](https://gyazo.com/4c444fc3e2ce5451ca742c0600f918e0).
The error results from the lack of initialization of the xDLMS_Context.InInfo attribute in the Association LogicalName object, as well as the incorrect creation by the constructor of the object of the class GXDLMSVariant from the DLMS_Conformance object.
My edits in the part of the Option are shown [here](https://github.com/systems-measure/Gurux.DLMS.cpp/tree/issue_invalid_re…).
However, how and how to initiate DLMS_ContextinInfo has not figured it out.
How to initiate DLMS_ContextInfo?
Best regards, Dmitry
9 years 1 month ago
We have not released new version from C++ as open source. We are releasing it on next week.
Jon Lin
7 years 9 months ago
how to set device properties of GuruxDLMSServerExample
Please comment how to set device properties in GXSDLMSDirector's Device Properties dialog for connecting success.
Hi Jon Lin,
If you are using Logical Name referencing with HDLC framing, select Gurux as a manufacturer and
TCP/IP port as 4061.
Jon Lin
In reply to GuruxDLMSServerExample by Kurumi
Dear Mikko,
Thanks a lot for your reply.
I've done successfully to connect GuruxDLMSServerExample with GXDLMSDirector.
Jon Lin
10/23/2018
  • Kak_maKr
  • Marciaannem
  • Scottstike
  • rcprociG
  • helloworld
