  3. GuruxDLMSServerExample. Error Occurred While Reading The Association Logical Name
GuruxDLMSServerExample. Error occurred while reading the Association Logical Name
By dlsh , 19 June, 2017
Hello
Let's start the example of GuruxDLMSServerExample.
When you read the Association Logical Name, the error
*Access Error: Device reports a hardware fault.*
appears through the GXSDLMSDirector. [Image](https://gyazo.com/4c444fc3e2ce5451ca742c0600f918e0).
The error results from the lack of initialization of the xDLMS_Context.InInfo attribute in the Association LogicalName object, as well as the incorrect creation by the constructor of the object of the class GXDLMSVariant from the DLMS_Conformance object.
My edits in the part of the Option are shown [here](https://github.com/systems-measure/Gurux.DLMS.cpp/tree/issue_invalid_re…).
However, how and how to initiate DLMS_ContextinInfo has not figured it out.
How to initiate DLMS_ContextInfo?
Best regards, Dmitry
9 years 5 months ago
We have not released new version from C++ as open source. We are releasing it on next week.
Jon Lin
8 years 1 month ago
how to set device properties of GuruxDLMSServerExample
Please comment how to set device properties in GXSDLMSDirector's Device Properties dialog for connecting success.
8 years 1 month ago
Hi Jon Lin,
If you are using Logical Name referencing with HDLC framing, select Gurux as a manufacturer and
TCP/IP port as 4061.
Jon Lin
8 years 1 month ago
In reply to GuruxDLMSServerExample by Kurumi
Dear Mikko,
Thanks a lot for your reply.
I've done successfully to connect GuruxDLMSServerExample with GXDLMSDirector.
Jon Lin
10/23/2018
